White Durable HDMI Cable Reinforced Aramid Fiber EMI Protection TPE Cable. This HDMI cable with Ethernet withstands the daily demands of connecting your HDMI devices. Tested to endure strenuous wear and tear, the rugged HDMI cable is a must-have for both business and consumer applications.
Built for Daily Use
This Premium Certified HDMI cable has aramid fiber reinforcement that braces it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cord.
Premium High Speed HDMI Cable Key Features
Aramid fiber adds strength and durability to the cable
Insulated conductors reduce friction, provide more flexibility
EMI protection with aluminum-mylar foil with braided shielding
TPE cable jacket is more flexible than a standard PVC cable
Flexible Strain Relief
The cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
Connector Key Features
HDMI gold plated connector with metal shield protects the circuit board from EMI and reinforces the connection point
Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle
Supporting all HDMI 2.0 specifications, this 6ft white HDMI Premium Certified cable supports resolutions up to 4k 60Hz with a bandwidth of up to 18Gbps. The short male to male HDMI cable also supports HDR for higher contrast ratio and vivid colors providing an enriched and enjoyable viewing experience.
RHDMM2MPW is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Note: DuPont and Kevlar are trademarks or registered trademarks of E.I. du Pont de Nemours and Company.
Built for Daily Use
This Premium Certified HDMI cable has aramid fiber reinforcement that?braces?it from the stress of frequent bends. This also lets the cable flex without?over-stretching?or damaging?the core of the cord. -
The cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle. -
Connector Key Features • HDMI gold plated connector with metal shield protects the circuit board from EMI and reinforces the connection point • Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle
Supporting all HDMI 2.0 specifications, this 6ft white HDMI Premium Certified cable?supports?resolutions up to 4k 60Hz with a bandwidth of up to 18Gbps. The short male to male HDMI cable also supports HDR for higher contrast ratio and vivid colors providing?an?enriched?and enjoyable?viewing experience. RHDMM2MPW is backed by a StarTech.com lifetime warranty and free lifetime technical support. Note: DuPont and Kevlar are trademarks or registered trademarks of E.I. du Pont de Nemours and Company.
- Startech HDMI cable with Ethernet - 2 m
- Cable
- Premium High Speed - HDMI cable with Ethernet
- American Wire Gauge (AWG)
- 30
- Cable Length
- 2 m
- White
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- 4K format support, HDR support, 32 audio channels, EMI/RFI protection
- Limited lifetime warranty
- Designed For
- P/N: TB3DKM2HDL
- Cable Type
- 30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Cable Length
- 2 m
- Plated Connector
- Gold
- White
- Connector
- 19 pin HDMI Type A - male
- RoHS, WEEE, REACH
- Shipping Width
- 18.2 cm
- Shipping Depth
- 15 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 103 g
- Limited warranty - lifetime
- Designed For
- P/N: TB3DKM2HDL
StarTech.com Triple Monitor Desk Mount | In Stock | £180.85 |
StarTech.com Triple Monitor Desk Mount | In Stock | £169.08 |
StarTech.com Crossbar Dual Monitor Stand | In Stock | £86.32 |
StarTech.com Dual Monitor Vertical Mount | In Stock | £121.00 |
