StarTech.com 2ft 2-Port USB to RS232 Serial Adapter
Quicklinx: HM9WWS00 Mfr#: 2P1FFC-USB-SERIAL
Length: 60cm
Hurry, only 1 left in stock!
£49.17 ex VAT
£59.00 inc VAT
Add RS-232 serial communication support to USB-A enabled Data Terminal Equipment (DTE - e.g., desktop or laptop), using this 2ft (61cm) straight through 2-Port USB to Serial Adapter Cable.
  • Serial Port Expansion
    The Dual-Port USB Serial Adapter adds two RS-232 serial DB/DE-9 (male) connectors to a desktop or laptop via a single USB Type-A port. Secure the adapter to a serial device, using pre-installed and removable slotted DB-9 nuts or install the included DB-9 thumbscrews for compatibility with other serial peripheral devices or cables.
  • LED Indicators
    Data transmission and reception LED indicators for each port on the adapter provide real-time monitoring of port activity. The USB LED indicates when the adapter has successfully enumerated on the desktop or laptop. All the LEDs aid with diagnostics and troubleshooting.
  • Seamless Connectivity
    The adapter is compatible with Windows, macOS, ChromeOS, and Linux. Drivers automatically install to Windows 7 and newer versions, macOS 10.15 and above, and Linux. The USB to RS-232 adapter features COM retention, which automatically reassigns the COM port value if the cable is disconnected and reconnected, or if the system is rebooted.
  • Built To Last
    The rugged TPE construction and Level-4 ESD protection (15kV air and 8kV contact) enhance the reliability and longevity of the USB to Serial Adapter. Copper shielding minimizes Electromagnetic and Radio Frequency Interference (EMI and RFI). Gold-plated connectors enhance signal conductivity. The included mounting bracket allows the hub of the serial adapter to be mounted to a desired surface.
StarTech.com 2ft (60cm) 2-Port USB to Serial Adapter Cable, Interchangeable DB9 Screws/Nuts, COM Retention, USB-A to DB9 RS232, FTDI, Level-4 ESD Protection, Windows/macOS/ChromeOS/Linux - Rugged TPE Construction (2P1FFC-USB-SERIAL) - USB / serial cable - USB to DB-9 - 60 cm
USB / serial cable
EMI/RFI protection, electrostatic discharge (ESD) protection, FTDI controller, LED status indicator, TPE connector housing, bus powered
Length
60 cm
Connector
4 pin USB Type A - male
Connector (Second End)
2 x 9 pin D-Sub (DB-9) - male
USB / USB 2.0
USB / serial cable
Shielding Material
Copper
Plated Connector
Gold
Length
60 cm
110 g
Connector
Mounting bracket
USB / USB 2.0, RS-232
Shipping Width
22.5 cm
Shipping Depth
15.5 cm
Shipping Height
5.5 cm
Shipping Weight
160 g
HM9W StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.20
HM9W StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.81
HM9W StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.38
HM9W StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.22
HM9W StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.00
HM9W StarTech.com 13ft 2-Port USB to RS232 Serial Adapter In Stock £57.30
Length: 60cm
