StarTech.com 28" Monitor Privacy Filter
Quicklinx: HDGSWS00 Mfr#: 2869-PRIVACY-SCREEN
Accessory Type: Privacy Screen
£79.74 ex VAT
£95.68 inc VAT
Monitor privacy screen features a universal design compatible with 28" 16:9 aspect ratio monitors. The anti-glare design provides visual comfort while reducing the adverse effects of blue light emitted from the display. Reversible design allows you to quickly adjust to different light conditions throughout the day.
  • Prevent Visual Eavesdropping
    This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your computer's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
  • Reversible Filter
    The privacy screen protector is reversible, with a matte anti-glare side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint and scratch resistant coating. The privacy shield has a light transmittance of 57.5% providing optimal screen brightness and enhanced levels of privacy.
  • Hassle-free Installation
    Affix the privacy screen shield using the provided residue-free transparent adhesive strips or the side mounting tabs. The cutout on the top corner of the privacy screen makes it easy to remove for sharing content with trusted audiences or switching between the matte and glossy finishes.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort with this blue light-reducing privacy shield. It blocks up to 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 28-inch 16:9 Computer Monitor Privacy Filter, Anti-Glare Privacy Screen with 51% Blue Light Reduction, Black-out Monitor Screen Protector w/+/- 30 deg. Viewing Angle, Matte and Glossy Sides (2869-PRIVACY-SCREEN) - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal)
Package Content
Adhesive strips, wiping cloth, quick start guide, mounting tabs
Transparent
Product Material
Plastic
62.2 cm 34.3 cm
100 g
Display Screen Size Compatibility
28" wide
Anti-glare, reversible, fingerprint-resistant coating, +/- 30° visible angle, Hassle-free installation, 51% blue light reduction
Product Material
Plastic
Package Content
62.2 cm
34.3 cm
Thickness
0.4 mm
100 g
74 cm x 42.5 cm x 0.2 cm / 500 g
28" wide
Transparent
Finish
Glossy, matte
Display Filter
Aspect Ratio
16:9
Scratch Resistant
Limited warranty: - 2 years
HDGS StarTech.com Privacy Screen Adhesive Strips In Stock £6.82
