StarTech.com's DuraRak 25U 4 Post Open Frame Rack/Cabinet provides a durable, open air housing for rackmount servers and networking equipment. The equipment rack/cabinet features heavy gauge mounting rails to ensure a stable installation platform and adjustable posts for flexible installation. The 25U rack is compliant with EIA-RS-310C standards, offering a universal design that's compatible with equipment from popular manufacturers. Plus, the equipment rack is flat-packed, reducing shipping costs and simplifying handling and assembly. The DuraRak 25U 4-Post Open Racks offer a durable housing for valuable equipment.
- StarTech.com 25U Open Frame Server Rack - 994lb Capacity - 4 Post Adjustable Depth (18.3" to 39.3") Network/Communications Equipment Rack w/ Casters (4POSTRACK25) - rack - 25U
- Product Type
- Rack
- Flat black
- Height (Rack Units)
- 25U
- 57.1 cm x 100 cm x 122.5 cm
- 39 kg
- 3-year warranty
- Designed For
- P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
- Product Type
- Rack
- 25U
- 57.1 cm
- 100 cm
- 122.5 cm
- 39 kg
- Flat black
- Weight Limit
- 450 kg
- Limited warranty: - 3 years
- Designed For
StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £473.44 |
StarTech.com 25U Adjustable Depth 4 Post Open Frame Server Rack Cabinet | In Stock | £284.04 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £83.25 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £45.20 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £75.78 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £41.78 |
StarTech.com Caster Kit for Open Frame Rack - 4POSTRACK | In Stock | £41.74 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £85.18 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.28 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £33.14 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £33.34 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £15.71 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £31.71 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £60.18 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £63.56 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £22.78 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £87.01 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £115.35 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £66.49 |
StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £82.01 |
StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £85.25 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £37.77 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £89.58 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £48.80 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £43.24 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £32.89 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £3.39 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £7.09 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £37.26 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £44.18 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £24.99 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £63.56 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £33.88 |
StarTech.com Portable Server Rack - 9U | In Stock | £253.32 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £27.44 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £21.95 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £60.18 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £31.01 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £17.89 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £33.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £18.70 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £29.13 |
StarTech.com 19in Cable Management Panel | In Stock | £23.93 |
StarTech.com 18U Server Rack Enclosure | In Stock | £436.98 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £172.30 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £196.32 |
StarTech.com 12U Server Rack Enclosure | In Stock | £388.15 |
StarTech.com 12U Server Rack Enclosure | In Stock | £330.64 |
StarTech.com 12U Server Rack Enclosure | In Stock | £393.33 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £31.93 |
