Extend the distance between a computer and a USB 2.0 device by 25 meters. The USB2AAEXT25M 25m Active USB 2.0 Extension Cable offers one USB-A male connector and one USB-A female connector, and provides an active extension of USB 2.0 devices of up to 25-meters (80-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Plus you can daisy chain 2 cables for a total USB extension of up to 50-meters.
If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter (provided with the cable).
The USB2AAEXT25M repeater cable supports the full USB 2.0 bandwidth of 480 Mbps.
- StarTech.com 25m USB 2.0 Active Extension Cable M/F - 25 meter USB A Male to USB A Female USB 2.0 Repeater / Extender Cable - Black - 80ft (USB2AAEXT25M) - USB extension cable - USB to USB - 25 m
- Technology
- Shielded
- Active cable (signal regeneration), LED power indicator
- Length
- 25 m
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: SVA5H2NEUA, UUSBOTG
- Technology
- Shielded
- Plated Connector
- Nickel
- Length
- 25 m
- Black
- Connector
- USB / USB 2.0, Plug and Play, FCC, RoHS
- 2-year warranty
- Designed For
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.02 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.15 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.29 |
StarTech.com 20m USB 2.0 Active Extension Cable - M/F | In Stock | £79.81 |
StarTech.com 15m USB 2.0 Active Extension Cable - M/F | In Stock | £63.27 |
