StarTech.com 25ft. Hook and Loop Roll - Yellow - Reusable
Quicklinx: FKDYWS00 Mfr#: HKLP25YW
Hurry, only 3 left in stock!
£4.39 ex VAT
£5.26 inc VAT
This 25 ft. roll of hook and loop roll tape makes it easy to keep your cables neat and tidy by binding them together or binding them to a structure.
This roll of hook and loop fastener straps offers a quick and easy solution for bundling cables together and securing your cables for better routing. Help protect your equipment by reducing cable tension and preventing excessive heat caused by unorganized cables restricting airflow.
You can cut the roll of hook and loop fastener fabric to size using household scissors, meaning you can choose the perfect length for your specific application.
While the most common use for this hook-and-loop fabric is binding and routing cables, you can also use it for other materials in your IT environment such as tools or raceways. The reusable tie wraps are easy to remove and adjustable, avoiding the hassle and waste of traditional zip ties.
  • Hassle-free cable management
  • Customize the length of your cable tie
  • Versatile fastening solution
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. This roll of cable tie is backed by a StarTech.com 2-year warranty and free lifetime technical support
StarTech.com 25ft Hook and Loop Roll, Cut-to-Size Reusable Cable Ties, Bulk Industrial Wire Fastener Tape/Adjustable Fabric Wraps Yellow/Resuable Self Gripping Cable Management Straps - Adjustable Loop Ties (HKLP25YW) - hook & loop fastener
Hook & loop fastener
1.9 cm 0.238 cm
Length
7.62 m
135 g
Yellow
P/N: CABSHF2POST2, HKLP25, HKLP25BL, HKLP25GN, HKLP25RD
1.9 cm
0.238 cm
Length
7.62 m
135 g
Enclosure Colour
Yellow
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
140 g
FKDY StarTech.com 25ft. Hook-and-Loop Cable Tie In Stock £4.31
FKDY StarTech.com 25ft. Hook and Loop Roll - Blue - Reusable In Stock £4.39
FKDY StarTech.com 100ft. Hook and Loop Roll - Blue - Reusable In Stock £17.95
FKDY StarTech.com 50ft. Hook and Loop Roll - Blue - Reusable In Stock £9.05
FKDY StarTech.com 100ft. Hook and Loop Roll - Yellow - Reusable In Stock £10.68
FKDY StarTech.com 25ft. Hook and Loop Roll - Red - Reusable In Stock £4.39
Type: Hook and Loop Fastener
