The StarTech.com 25-Pack Universal Laptop Lock offers a solution to secure laptops in any professional or educational setting. With compatibility across Noble Wedge, Nano, and K-Slot, this keyed alike locking cable is designed to fit a wide range of devices, providing flexibility and ease of use. The package includes 25 laptop security locks, each made from steel and durable plastic, ensuring protection against theft. Additionally, the set comes with 25 hook-and-loop straps, 75 lock spacers, and 4 keys, making it a choice for mass deployment in organizations looking to protect their assets. TAA compliance assures that this security solution meets the standards required for government procurement. Whether for individual use or as part of a larger security strategy, the StarTech.com laptop lock offers protection in any setting.
Versatile compatibility
Designed to fit a wide range of laptops, this security cable lock is compatible with Noble Wedge, Nano, and K-Slot, ensuring broad application across different brands and models. -
Robust construction
Crafted from steel and durable plastic, the lock offers reliable protection against theft, making it a safeguard for your device in various environments. -
Comprehensive package
Each package includes 25 laptop security locks, 25 hook-and-loop straps, 75 lock spacers, and 4 keys, providing everything needed for immediate implementation in educational or corporate settings.
- StarTech.com 25-Pack Universal Laptop Lock 6.6ft, Keyed Alike Locking Cable, Security Cable, Compatible w/Noble Wedge/Nano/K-Slot, Anti-Theft Cut-Resistant Cable - TAA - security cable lock
- Product Type
- Security cable lock
- Packaged Quantity
- 25 (specifications are for single item)
- Package Content
- 25 Laptop Security Locks, 4 keys, 75 lock spacers, 25 Hook-and-Loop Straps, quick start guide
- Silver, black
- Product Material
- Plastic, steel
- 4 cm 2 cm
- Length
- 2 m
- 125 g
- Kensington Nano Slot, Kensington Standard Slot (K-Slot), Noble Wedge Slot, anti-theft protection
- 2-year warranty
- Packaged Quantity
- Product Type
- Product Material
- Plastic, steel
- Package Content
- 4 cm
- 2 cm
- Length
- 2 m
- 125 g
- Shipping Dimensions (WxDxH) / Weight
- 25.7 cm x 32.5 cm x 13 cm / 3.5 kg
- Silver, black
Security Cable Lock
- Intended For
- Notebook
- Lock Type
- Nano, noble, noble wedge
- Lock Method
- Key
- TAA Compliant
- Limited warranty: - 2 years
- -20 °C
- 40 °C
