The 25-Pack Universal Laptop Lock is a versatile solution providing flexibility and convenience.
Adaptable security
A unique on-the-fly lock tip mechanism allows to quickly adapt the lock tip to different security slots. Simply rotate the lock selection dial to change the shape of the lock tip to match the security slot, all without the need to carry different lock tips or use special tools. The cut-resistant steel security cable is 6.6 ft. (2 m) long and 0.17 in (4.4 mm) thick, providing reach and durability. -
Serialized combination lock
Each lock comes with its own pre-set combination code for streamlined security management for IT administrators working with multiple locks. -
Widely compatible
The versatile bulk-pack security lock is not limited to laptops or notebooks only. Use this lock to secure other devices such as docking stations, monitors, printers, SFF computers, projectors, oscilloscopes, or other office and lab equipment, expanding its utility. The lock is future-proof as it works with previous and newer computers from various brands. Different thickness spacers are provided to ensure a better fit for your device. -
Full-motion lock design
The diameter of the lock head is 0.4 in (14 mm) and features a ball joint design that allows for 360° rotation and 90° pivot of the lock head. This flexibility reduces coiling and minimizes strain on the notebook slot, enhancing durability and usability. -
Flexible installation
Simply loop the cable through a grommet hole or around a desk leg. Ideal for tradeshows and product exhibits.
- StarTech.com 25-Pack Laptop Lock, Compatible w/Noble Wedge/Nano/K-Slot - security cable lock
- Product Type
- Security cable lock
- Packaged Quantity
- 25 (specifications are for single item)
- Package Content
- 25 Laptop Security Locks, 25 Hook-and-Loop Straps, 75 Bumper Spacers, 25 Quick-Start Guide
- Black, silver
- Product Material
- Plastic, steel
- 1.4 cm 4.6 cm
- Length
- 2 m
- 146 g
- Theft protection, Kensington Nano Slot, Noble Wedge Slot, Kensington Standard Slot (K-Slot)
- 2-year warranty
- Packaged Quantity
- Product Type
- Product Material
- Plastic, steel
- Package Content
- 1.4 cm
- 4.6 cm
- Length
- 2 m
- 146 g
- Shipping Dimensions (WxDxH) / Weight
- 17.4 cm x 27.3 cm x 23.6 cm / 3.9 kg
- Black, silver
Security Cable Lock
- Intended For
- Notebook, docking station
- Lock Type
- Wedge, nano, standard, noble wedge, noble
- Lock Method
- Combination
- TAA Compliant
- Limited warranty: - 2 years
StarTech.com Laptop Cable Lock Anchor - Computer Security Cable Anchor | In Stock | £10.22 |
StarTech.com Laptop Cable Lock Anchor - Large | In Stock | £11.18 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £8.98 |
StarTech.com 25-Pack Universal Laptop Lock | In Stock | £627.35 |
StarTech.com 3-in-1 Universal Laptop Lock | In Stock | £27.51 |
StarTech.com Universal Laptop Cable Lock | In Stock | £25.07 |
