This 25ft Cross Wired Serial/Null Modem Cable features two DB9 female connectors, allowing you to connect a 9-pin serial port to a serial port, or transfer files from PC to PC via serial connection.
Flexible connection options
With a length of 25 ft, this null modem cable allows for versatile setups, accommodating different arrangements between devices without restriction. -
Dual female connectors
The cable is equipped with female 9-pin D-Sub connectors on both ends, ensuring compatibility with various serial devices requiring gender-specific connections. -
Enhanced data integrity
Engineered for reliable data transfer, this cable minimizes signal loss and ensures steady communication between devices, proving essential in critical applications.
- StarTech.com 25 ft Cross Wired DB9 Serial Null Modem Cable - F/F - 25ft DB9 Null Modem Cable (SCNM9FF25) - null modem cable - 7.6 m
- Null modem cable
- Length
- 7.6 m
- Connector
- 9 pin D-Sub (DB-9) - female
- Connector (Second End)
- Limited lifetime warranty
- Designed For
- P/N: 10PKPCI1S550, EC1S232U2, EC1S952, EC2S952, IC485S, ICUSB232DB25, ICUSB232INT1, ICUSB232INT2, PCI1S550, PCI2S1P, PCI2S232485I, PCI2S550, PCI2S550_LP, PCI2S950, PCI4S550, PCI4S550N, PEX2S1P553B, PEX8S950LP
- Network Cable Type
- Null modem cable
- Length
- 7.6 m
- Connector
- Designed For
