This 25ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F - 25ft VGA Extension Cable (MXT101HQ_25) - VGA extension cable - 7.6 m
- Technology
- Coaxial
- Molded
- Length
- 7.6 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- HD-15 (VGA) - female
- Limited lifetime warranty
- Designed For
- P/N: DP2VGAMM6, DP2VGAMM6B, DS128, DSRXL, HD2VGAMM6, MXT101MM, ST122PROEU, ST122PROGB, ST124PROEU, SV231USBLC, SV431USB, USBVGADOCK2
- Technology
- Coaxial
- Molded
- Length
- 7.6 m
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 15 pin HD D-Sub (HD-15) - female
- Designed For
