StarTech.com 25 ft Cat5e Blue Molded Crossover RJ45 UTP Cat5e Patch Cable - 25ft Patch Cord
Quicklinx: 400MWS00 Mfr#: M45CROSS25BL
StarTech.com's Cat5e UTP Crossover Patch Cables offer reliable Ethernet connections. This 25ft cable meets or exceeds all Category 5e specifications and features a durable blue jacket that simplifies departmental color coding, while providing rugged flexibility for network connections.
To ensure long-lasting performance, StarTech.com's high quality Cat5e UTP Crossover Patch Cables offer PVC molded strain relief that prevents the RJ45 connector termination point from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
StarTech.com's 25ft blue Cat5e UTP Crossover Patch Cable is constructed of only top quality materials to ensure optimum durability.
StarTech.com Cat 5e cables are manufactured with copper conductors. While many cable manufacturers offer a "cheaper" cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value for your cable investment.
StarTech.com Cat 5 cables are constructed with 24 gauge copper wire to support a broad range of Ethernet applications, such as Power over Ethernet (PoE). Because StarTech.com uses a high quality 24 gauge wire, its cables easily sustain the nominal voltage (48v) capability required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat build up, equipment damage and potentially, fire.
StarTech.com Cat 5 cables offer high quality connectors comprised of 50 micron gold to ensure optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • 100% copper - a better value
  • 24 gauge wire
  • 50 micron gold connectors
StarTech.com Molded Cat5e Crossover UTP Patch Cable - crossover cable - 7.6 m - blue
Crossover cable - CAT 5
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
7.6 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
7.6 m
Blue
Connector
RJ-45 - male
RJ-45 - male
