Connect VGA video and a PS/2 keyboard and mouse set using a single thin KVM cable
StarTech.com's professional line of 3-in-1 PS/2 KVM cables are specifically designed to work with your StarView or Server Remote Control KVM switch, integrating the necessary PS/2 peripheral connections as well as the VGA connection into a single cable - reducing tangles while maintaining excellent performance.
This 25ft 3-in-1 PS/2 KVM switch cable features an ultra-thin design and is constructed of only high quality materials. Designed for durability and long-term reliability, this cable is backed by StarTech.com's Lifetime Warranty.
The StarTech.com Advantage
- Unique design minimizes the number of cables required
- StarTech.com 3-in-1 Ultra Thin PS/2 KVM Cable - keyboard / video / mouse (KVM) cable - 7.62 m
- Keyboard / video / mouse (KVM) cable
- Length
- 7.62 m
- Connectors
- 15 pin HD D-Sub (HD-15) - male
- Connectors (Second End)
- 15 pin HD D-Sub (HD-15) - male ¦ 2 x 6 pin mini-DIN (PS/2 style) - male
- Limited lifetime warranty
- Designed For
- P/N: CAB1631HD, CAB831HD, CABCONS16, CABCONS1716I, CABCONS8, RACKCONS1908, RACKCONS1916, SV565UTP, SV831DUSBA, SV831HD, SV841HDIE, SV841HDIEGB
- Length
- 7.62 m
- Connectors
- Designed For
StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £265.47 |
