StarTech.com 25 ft 3-in-1 PS/2 KVM Extension Cable
Quicklinx: 3ZZ0WS00 Mfr#: 3N1PS2EXT25
The StarTech.com PC99 3-in-1 Extension Cable allows keyboard, monitor, and mouse cables to be extended without the mess and tangle of 3 separate traditional cables. The exclusive design takes 3 separate extension cables and fuses them into 1 neat tangle-free cable. Each connector end is color coded according to PC99 specifications for ease of identification when connecting the peripherals. The video component of the cable is constructed with high-quality mini-coaxial wire for crystal clear video quality at any resolution. Double shielding and a ferrite core on the video cable virtually eliminate any external signal interference. If a speaker extension is also required, check out the StarTech.com 4-in-1 extension cables.
StarTech.com 25 ft 3-in-1 PS/2 KVM Extension Cable - keyboard / video / mouse (KVM) extension cable - 7.5 m
Keyboard / video / mouse (KVM) extension cable
Shielded
Length
7.5 m
Connectors
15 pin HD D-Sub (HD-15) - male , 2 x 6 pin mini-DIN (PS/2 style) - male
Connectors (Second End)
15 pin HD D-Sub (HD-15) - female , 2 x 6 pin mini-DIN (PS/2 style) - female
Shielded
Length
7.5 m
Connectors
