StarTech.com 25" Monitor Privacy Screen
Quicklinx: HSV8WS00 Mfr#: 2569-PRIVACY-SCREEN
Hurry, only 3 left in stock!
£66.53 ex VAT
£79.83 inc VAT
The StarTech.com 25-inch 16:9 Computer Monitor Privacy Screen/Filter is a solution for safeguarding your digital privacy. Perfectly sized for 25" monitors, this filter reduces the chances of visual hacking by limiting the viewing angle to +/- 30°, ensuring that only the person directly in front of the monitor can see the screen clearly. Not only does it protect your information, but it also features a dual-finish surface that allows you to switch between glossy for clarity and matte to minimize glare, making it ideal for any lighting condition. Additionally, it's designed to reduce blue light exposure and is equipped with a scratch and fingerprint-resistant coating, preserving both your eyesight and the screen's appearance. Installation is straightforward, offering both Plug-and-Play and adhesive options to suit your preference, and it comes with everything needed for a quick setup. Whether you're working in an open office, traveling, or in any public space, this privacy screen keeps your confidential and sensitive information protected from prying eyes while ensuring a comfortable and safe viewing experience.
  • Enhanced privacy
    This 25-inch 16:9 Computer Monitor Privacy Screen/Filter from StarTech.com ensures your sensitive information remains confidential, thanks to its +/- 30° visible angle, making it difficult for onlookers to view your screen from the side.
  • Versatile viewing
    Featuring a unique glossy/matte surface finish, this privacy screen offers the flexibility to choose your preferred viewing experience while reducing glare and harmful blue light, making it easier on the eyes.
  • Durable design
    Crafted with a scratch-resistant and fingerprint-resistant coating, this display privacy filter stands up to daily wear and tear, maintaining a clear view and clean appearance.
  • Easy installation
    With both Plug-and-Play and adhesive installation options, along with a mounting kit that includes adhesive strips, mounting tabs, and a wiping cloth, setting up your privacy screen is hassle-free and adaptable to your needs.
StarTech.com 25-inch 16:9 Computer Monitor Privacy Screen/Filter - display privacy filter - 25"
Display privacy filter
Installation Type
Removable - plug-in/adhesive
Package Content
Adhesive strip, wiping cloth, mounting tabs kit
Transparent
Display Screen Size Compatibility
25"
Product Material
Plastic
31.2 cm x 55.4 cm x 0.04 cm
100 g
Package Content
25"
Product Material
Plastic
31.2 cm - 55.4 cm - 0.04 cm
100 g
42.5 cm x 74.5 cm x 0.3 cm / 600 g
Transparent
Display Filter
Installation Type
Aspect Ratio
16:9
Surface Finish
Glossy/matte
Scratch Resistant
Mounting Kit
Included
Anti-glare, fingerprint-resistant coating, horizontal orientation, +/- 30° visible angle, blue light reduction, 60% light transmittance
