StarTech.com 24in Right Angle SATA Cable
Quicklinx: 76SPWS00 Mfr#: LSATA24RA2
A space-saving, latching right angle SATA hard drive cable, for installations in tight spaces.. The LSATA24RA2 Right Angle (90-degree) SATA Cable enables you to plug in your SATA hard drive in hard to reach areas or tight spaces, using right-angled SATA connectors to reduce the amount of space required at the connection point and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com Right Angle Latching SATA Serial ATA Cable - SATA cable - 61 cm
SATA cable
Interface Speed
Serial ATA 150/300
90° connector, right-angled connector
Length
61 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
Red
P/N: PEXSAT32, SATSASBAY3BK
Storage Cable Type
SATA cable
Interface Speed
Serial ATA 150/300
Length
61 cm
Red
Connector
