The LSATA24 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
- StarTech.com 24in Latching SATA Cable - SATA cable - 61 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Latched
- Length
- 61 cm
- Connector
- 7 pin Serial ATA - receptacle
- Connector (Second End)
- Red
- Limited lifetime warranty
- Designed For
- P/N: PEXSAT31E1, PEXSAT32, SATABAY425BK, DRW110SATBK
- Storage Cable Type
- SATA cable
- Interface Speed
- Latched
- Length
- 61 cm
- Red
- Connector
- RoHS
- Designed For
- StarTech.com 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card, 2 Port SATA 6 Gbps PCI Express SATA Controller Card, 4 Drive 2.5in Removable Mobile Rack SAS SATA Backplane
