StarTech.com 24in Latching SATA Cable
Quicklinx: 4LTLWS00 Mfr#: LSATA24
Length: 61cm
Type: ATA
33 in stock
£4.46 ex VAT
£5.35 inc VAT
The LSATA24 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 24in Latching SATA Cable - SATA cable - 61 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Latched
Length
61 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: PEXSAT31E1, PEXSAT32, SATABAY425BK, DRW110SATBK
Storage Cable Type
SATA cable
Interface Speed
Latched
Length
61 cm
Red
Connector
RoHS
StarTech.com 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card, 2 Port SATA 6 Gbps PCI Express SATA Controller Card, 4 Drive 2.5in Removable Mobile Rack SAS SATA Backplane
Length: 61cm
Type: ATA
Price Range Ex VAT: 0 - 50
