The ICUSB232INT2 USB to serial adapter lets you add 2 RS232 ports to any desktop system that is equipped with an available USB motherboard header. Unlike standard USB to serial cables, this cable is designed for use inside the PC case, affording an entirely internal solution with no mess or extra adapters needed.
This compact and simple USB adapter offers a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
- StarTech.com Motherboard Serial Port - Internal - 2 Port - Bus Powered - FTDI USB to Serial Adapter - USB to RS232 Adapter (ICUSB232INT2) - serial adapter - USB - RS-232 x 2
- Serial adapter
- Form Factor
- Internal
- Interface (Bus) Type
- USB
- Ports
- RS-232 x 2
- 12 cm x 6.8 cm x 1.9 cm
- 63 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 115.2 Kbps
- System Requirements
- Microsoft Windows CE 4.2, Microsoft Windows CE 5.0, Microsoft Windows CE 6.0, Microsoft Windows XP Embedded, Microsoft Windows 98 Second Edition, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows 11, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Linux Kernel 3.0 or later, Linux LTS versions only
- 2-year warranty
- Serial adapter
- Form Factor
- Internal
- USB
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- 115.2 Kbps
- 2 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
- 1 x USB
- Cables Included
- 1 x USB cable - 61 cm
- WHQL, RoHS
- OS Required
- 12 cm
- 6.8 cm
- 1.9 cm
- 63 g
- Limited warranty - 2 years
- -40 °C
- 85 °C
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.20 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £30.95 |
StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F | In Stock | £6.32 |
StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F | In Stock | £6.52 |
StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter | In Stock | £7.93 |
StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £44.84 |
StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter | In Stock | £45.09 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation | In Stock | £92.00 |
