StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter
Quicklinx: 7NZ5WS00 Mfr#: ICUSB232INT2
Type: Serial adapter
Compatibility: Mac, PC
Interface: USB
10 in stock
£35.31 ex VAT
£42.37 inc VAT
The ICUSB232INT2 USB to serial adapter lets you add 2 RS232 ports to any desktop system that is equipped with an available USB motherboard header. Unlike standard USB to serial cables, this cable is designed for use inside the PC case, affording an entirely internal solution with no mess or extra adapters needed.
This compact and simple USB adapter offers a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
StarTech.com Motherboard Serial Port - Internal - 2 Port - Bus Powered - FTDI USB to Serial Adapter - USB to RS232 Adapter (ICUSB232INT2) - serial adapter
Serial adapter
Internal
Interface (Bus) Type
USB
Ports
RS-232 x 2
12 cm x 6.8 cm x 1.9 cm
63 g
RS-232
Data Transfer Rate
115.2 Kbps
Serial adapter
Internal
USB
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
115.2 Kbps
2 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB
1 x USB cable - 61 cm
WHQL, RoHS
12 cm
6.8 cm
1.9 cm
63 g
-40 °C
85 °C
7NZ5 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.29
7NZ5 StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £3.90
7NZ5 StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.66
7NZ5 StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.53
7NZ5 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £14.62
7NZ5 StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £21.04
7NZ5 StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £35.13
7NZ5 StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F In Stock £5.96
7NZ5 StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter In Stock £17.28
7NZ5 StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter In Stock £35.31
7NZ5 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.07
Compatibility: Mac
Compatibility: PC
Interface: USB
Price Range Ex VAT: 0 - 50
