Organize up to 24 Cat6 patch cables. The C6PANEL24 24-port 110-type Rack Mount Cat 6 Patch Panel is color coded for both T568A and T568B wiring providing the perfect solution for any voice or LAN application.
For hassle-free connections, the patch panel offers straight Cat 6 ports with 110-type termination, making it easy to insert and remove your cables. The 24-port patch panel also offers a quick and easy way to identify your cable runs, with port numbers clearly marked on the back of each RJ45 port, and a writeable/erasable marking surface for each port on the front of the panel for efficient system management.
                Efficient organizationDesigned for optimal organization and efficiency, the StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel streamlines network cabling in any setup. Its compact 1U size fits seamlessly into any standard network rack, making it a suitable solution for managing multiple network connections in a confined space.
                High compatibilityWith a design that supports CAT 6 cabling, this patch panel ensures high-speed data transmission and is compatible with a wide range of networking equipment. Its 24 ports accommodate extensive network requirements, making it suitable for both small and large-scale operations.
                Durable constructionThe patch panel is built to withstand a wide range of environmental conditions, operating reliably in temperatures from -10°C to 60°C and humidity levels from 10 to 65%. This durability ensures stable network performance in various operating conditions.
- StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel - 24 port Network Patch Panel - RJ45 Ethernet 110 type Rack Mount Patch Panel 1U (C6PANEL24) - patch panel - 1U
- Product Type
- Patch panel - CAT 6
- Package Content
- 8 x screws
- 605 g
- Black
- Port Qty
- 24 ports
- Height (Rack Units)
- 1U
- 2-year warranty
- Designed For
- P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK1232WALHM, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2, WALLMOUNT4
- Product Type
- Package Content
- 8 x screws
- 1U
- 605 g
- Enclosure Colour
- Black
Cabling & Wiring
- Port Qty
- 24 ports
- Termination Type
- 110 type termination
- Connector Provided
- 24 x 110 female
- Limited warranty - 2 years
- -10 °C
- 60 °C
- 10 - 65%
- Designed For
- P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK119WALLV, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK219WALLV, RK219WALVO, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK319WALLV, RK3236BKF, RK419WALLV, RK419WALVO, RK419WALVS, RK419WALVSGB, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK616WALM, RK619WALL, RK619WALLGB, RK619WALLOH, RK619WALLV, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, WALLMOUNT4, WALLSHELF4U, WALLSHELF8U
