Set up 24 Cat6 connections using this feed through patch panel with pre-installed RJ45 couplers
Streamline rack-mounted network setups with this 24-Port 1U Feed-Through Patch Panel with preinstalled RJ45 UTP inline couplers. Designed for scalable enterprise networks, it provides a clean, ready-to-use solution for organizing Cat6 or Cat5e patch cables across standard 19-inch racks.
Quick and Simple Setup
Each port includes a factory-installed RJ45 coupler that supports Cat6 and Cat5e Ethernet cabling, with clearly numbered ports on the front panel to simplify identification, maintenance, and network reconfiguration. Instantly swap or replace patch cables as needed to restore connections quickly and minimize downtime.
Durable Construction
The steel housing features a black powder-coated finish for scratch resistance and long-term durability. An integrated cable management bar with tie-down slots reduces cable strain and maintains a tidy setup, improving passive airflow and ease of access when troubleshooting.
StarTech.com 24 Port 1U Patch Panel
