Organize up to 24 Cat6 cables using this blank UTP keystone patch panel and cable management bar
Deploy multiple Ethernet cable terminations in rack-mounted network setups, using this 24-Port 1U Blank Keystone Patch Panel with Cable Management Bar. It is designed for high-density installations such as wiring closets and data centers, where modular port configuration and clean cable routing are key to long-term serviceability.
Versatile Connectivity
The 1U keystone patch panel supports standard unshielded (UTP) RJ45 keystone jacks, matching Cat5e or Cat6 network cabling. Numbered port labels along the front panel provide quick identification for maintenance and troubleshooting.
Durable Construction
The steel housing features a black powder-coated finish for scratch resistance and long-term durability. An integrated cable management bar with tie-down slots reduces cable strain and maintains a tidy setup, improving passive airflow and ease of access when troubleshooting.
