The StarTech.com 24 in 16:9 Anti-Blue Light Filter is an essential accessory for anyone looking to protect their eyes and enhance their screen privacy. Designed specifically for 24" wide monitors, this filter effectively reduces blue light exposure, helping to minimize eye strain and fatigue during long hours of use. Its high light transmittance ensures that screen clarity is not compromised, while the inclusion of adhesive strips and a mounting tabs kit makes installation a breeze. Beyond eye comfort, it offers 4-way privacy protection, scratch resistance, and safeguards against dust and fingerprints, thanks to its durable plastic construction. Whether for work or leisure, this blue light screen filter is a smart addition for any computer user.
Enhanced visual comfort
The 24 in 16:9 Anti-Blue Light Filter from StarTech.com is designed to significantly reduce blue light exposure from your screen, providing enhanced visual comfort by minimizing eye strain and fatigue. -
Easy installation
Featuring both Plug-and-Play and adhesive options, this blue light screen filter offers a flexible installation process that is both quick and hassle-free, ensuring a secure fit for your 24" wide display. -
Durable and protective
Crafted from high-quality plastic, this display privacy filter is not only scratch resistant but also provides protection against dust and fingerprints, maintaining the pristine condition of your screen. -
Privacy enhancement
With its 4-way privacy protection, the filter ensures that your on-screen information remains confidential, preventing visual hacking from all sides in horizontal orientation.
- StarTech.com 24in 16:9 Anti-Blue Light Filter, BlueLight Screen Filter - display privacy filter - 24" wide - TAA Compliant
- Product Type
- Display privacy filter - 4-way
- Installation Type
- Removable - plug-in/adhesive
- Package Content
- Adhesive strips, wiping cloth, mounting tabs kit
- Display Screen Size Compatibility
- 24" wide
- Product Material
- Plastic
- 53.1 cm x 29.8 cm
- 70 g
- TAA Compliant
- 2-year warranty
- Product Type
- Package Content
- 24" wide
- Product Material
- Plastic
- 53.1 cm - 29.8 cm
- 70 g
- Shipping Dimensions (WxDxH) / Weight
- 57.3 cm x 36.8 cm x 0.6 cm / 439 g
Display Filter
- Privacy Protection
- 4-way
- Installation Type
- Aspect Ratio
- 16:9
- Scratch Resistant
- Mounting Kit
- Included
- Horizontal orientation, 90% light transmittance, anti-blue light, dust protection, fingerprint protection
- TAA Compliant
- Limited warranty - 2 years
StarTech.com Privacy Screen Adhesive Strips | In Stock | £6.19 |
