The StarTech.com 24in 16:10 Anti-Blue Light Filter is an essential accessory for anyone looking to protect their eyes and maintain privacy while working on their computer. Designed specifically for 24" wide screens, this filter not only reduces blue light exposure to help minimize eye strain and fatigue but also features 4-way privacy protection to keep on-screen information confidential. Its easy installation, with both plug-in and adhesive options, ensures a secure fit, while the durable plastic material provides scratch resistance and protection against dust and fingerprints. With 90% light transmittance, it maintains screen clarity and brightness, making it an ideal choice for both professional and personal use. Enhance your viewing experience and protect your screen with this display privacy filter.
Enhanced visual comfort
The 24in 16:10 Anti-Blue Light Filter from StarTech.com is designed to significantly reduce blue light exposure, providing enhanced visual comfort by minimizing eye strain and fatigue. Ideal for long hours in front of the screen, this filter ensures a healthier viewing experience. -
Easy installation
Featuring both plug-in and adhesive options, the installation process is simplified, allowing for a secure fit on 24" wide screens. The inclusion of adhesive strips and a mounting tabs kit ensures that the filter remains firmly in place, yet can be easily removed without leaving residue. -
Durable and protective
Crafted from high-quality plastic, this display privacy filter is not only scratch resistant but also offers protection against dust and fingerprints, maintaining a clean and clear screen. The 4-way privacy protection prevents visual hacking from all sides, ensuring that your information remains confidential.
- StarTech.com 24in 16:10 Anti-Blue Light Filter, BlueLight Screen Filter - display screen filter - 24" wide - TAA Compliant
- Product Type
- Display screen filter - 4-way
- Installation Type
- Removable - plug-in/adhesive
- Package Content
- Mounting tabs kit, adhesive strips, wiping cloth
- Display Screen Size Compatibility
- 24" wide
- Product Material
- Plastic
- 51.8 cm x 32.4 cm
- 70 g
- TAA Compliant
- 2-year warranty
- Product Type
- Package Content
- 24" wide
- Product Material
- Plastic
- 51.8 cm - 32.4 cm
- 70 g
- Shipping Dimensions (WxDxH) / Weight
- 57.7 cm x 37 cm x 0.4 cm / 351 g
Display Filter
- Privacy Protection
- 4-way
- Installation Type
- Aspect Ratio
- 16:10
- Scratch Resistant
- Mounting Kit
- Included
- Horizontal orientation, anti-blue light, 90% light transmittance, dust protection, fingerprint protection
- TAA Compliant
- Limited warranty - 2 years
StarTech.com Privacy Screen Adhesive Strips | In Stock | £6.33 |
