StarTech.com 24-inch Anti-Blue Light Filter
Quicklinx: HVM1WS00 Mfr#: 2461-ANTI-BLUE-LIGHT
Hurry, only 3 left in stock!
£39.05 ex VAT
£46.86 inc VAT
The StarTech.com 24in 16:10 Anti-Blue Light Filter is an essential accessory for anyone looking to protect their eyes and maintain privacy while working on their computer. Designed specifically for 24" wide screens, this filter not only reduces blue light exposure to help minimize eye strain and fatigue but also features 4-way privacy protection to keep on-screen information confidential. Its easy installation, with both plug-in and adhesive options, ensures a secure fit, while the durable plastic material provides scratch resistance and protection against dust and fingerprints. With 90% light transmittance, it maintains screen clarity and brightness, making it an ideal choice for both professional and personal use. Enhance your viewing experience and protect your screen with this display privacy filter.
  • Enhanced visual comfort
    The 24in 16:10 Anti-Blue Light Filter from StarTech.com is designed to significantly reduce blue light exposure, providing enhanced visual comfort by minimizing eye strain and fatigue. Ideal for long hours in front of the screen, this filter ensures a healthier viewing experience.
  • Easy installation
    Featuring both plug-in and adhesive options, the installation process is simplified, allowing for a secure fit on 24" wide screens. The inclusion of adhesive strips and a mounting tabs kit ensures that the filter remains firmly in place, yet can be easily removed without leaving residue.
  • Durable and protective
    Crafted from high-quality plastic, this display privacy filter is not only scratch resistant but also offers protection against dust and fingerprints, maintaining a clean and clear screen. The 4-way privacy protection prevents visual hacking from all sides, ensuring that your information remains confidential.
StarTech.com 24in 16:10 Anti-Blue Light Filter, BlueLight Screen Filter - display screen filter - 24" wide - TAA Compliant
Display screen filter - 4-way
Installation Type
Removable - plug-in/adhesive
Package Content
Mounting tabs kit, adhesive strips, wiping cloth
Display Screen Size Compatibility
24" wide
Product Material
Plastic
51.8 cm x 32.4 cm
70 g
TAA Compliant
Package Content
24" wide
Product Material
Plastic
51.8 cm - 32.4 cm
70 g
57.7 cm x 37 cm x 0.4 cm / 351 g
Display Filter
Privacy Protection
4-way
Installation Type
Aspect Ratio
16:10
Scratch Resistant
Mounting Kit
Included
Horizontal orientation, anti-blue light, 90% light transmittance, dust protection, fingerprint protection
TAA Compliant
HVM1 StarTech.com Privacy Screen Adhesive Strips In Stock £6.33
