StarTech.com 24" Monitor Privacy Screen
Quicklinx: HQ2TWS00 Mfr#: 2469A-PRIVACY-SCREEN
Accessory Type: Privacy Screen
22 In Stock
£79.40 ex VAT
£95.28 inc VAT
Hang this universal 24" 16:9 aspect ratio Monitor Privacy Screen on the top edge of a 24" monitor to obscure the view of sensitive on-screen information. Silicone bumpers ensure a secure and damage-free application.
  • Enhanced privacy
    Equipped with microlouver privacy technology, this 24-inch 16:9 Monitor Privacy Screen from StarTech.com ensures your data remains confidential. The technology allows only the person directly in front of the monitor to see the screen clearly, significantly reducing the risk of prying eyes from viewing sensitive information.
  • Versatile installation
    Designed for ease and flexibility, the hanging filter/shield offers a Plug-and-Play installation type, making it simple to attach or remove as needed. This feature is perfect for users who require privacy protection that can adapt to various situations.
  • Durable and clean
    The screen is not only scratch-resistant but also features a fingerprint-resistant coating, ensuring your display remains clear and readable. The glossy surface finish provides a crisp and vivid image quality, enhancing your viewing experience while protecting your screen.
StarTech.com 24-inch 16:9 Monitor Privacy Screen, Hanging Filter/Shield - display privacy filter - 24" wide
Display privacy filter - 2-way
Installation Type
Removable - plug-in
Package Content
Wiping cloth, 6 silicone bumpers
Display Screen Size Compatibility
24" wide
Product Material
Acrylic
32 cm x 54.7 cm x 2.3 cm
600 g
Package Content
24" wide
Product Material
Acrylic
32 cm - 54.7 cm - 2.3 cm
600 g
38.9 cm x 60.2 cm x 4 cm / 1 kg
Display Filter
Privacy Protection
2-way
Installation Type
Removable - plug-in
Aspect Ratio
16:9
Surface Finish
Glossy
Scratch Resistant
+/- 30° visible angle, horizontal orientation, hanging hook, microlouver privacy technology, fingerprint-resistant coating, 65% light transmittance
