StarTech.com 23.8in. Monitor Privacy Screen
Quicklinx: GKNJBTBS Mfr#: PRIVACY-SCREEN-238M
Accessory Type: Privacy Screen
£59.40 ex VAT
£71.28 inc VAT
The monitor privacy screen is easy to attach and remove. Simply attach the 23.8 inch privacy screen to your 16:9 aspect ratio display using the attachment strips or slide-mount tabs. This confidentiality screen filter is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
  • Protect Your Privacy
    The privacy screen protector for desktop monitors is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. You can have a peace of mind while working in the office or public environments because you know your screen is protected with the 30+/- degree privacy viewing angle. The cutout on the top corner of the privacy screen makes it easy to remove for sharing content with trusted audiences or switching between finishes.
  • Blue Light Reduction
    With working from home becoming more prominent and screen time on the rise, reducing blue light exposure is important. The monitor privacy film is designed to filter blue light (390nm~480 wavelength) and reduce digital eye strain.
  • Antimicrobial Protection
    Our privacy screens feature an anti-microbial coating on the matte-side of the filter. Embedded antimicrobial technology provides protection against bacterial microbes by continuously eliminating up to 99.99% of certain surface bacteria. Antimicrobial screen protectors are ideal for environments where disinfection is important.
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The TAA compliant PRIVACY-SCREEN-238M is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Monitor Privacy Screen for 23.8 inch PC Display, Computer Screen Security Filter, Blue Light Reducing Screen Protector Film, 16:9 Widescreen, Matte/Glossy, +/-30 Degree Viewing - Blue Light Filter - display privacy filter - 23.8" wide
Display privacy filter - 2-way
Installation Type
Removable - plug-in/adhesive
Package Content
Cleaning cloth, adhesive strips, slide mount tabs
Display Screen Size Compatibility
23.8" wide
Product Material
Plastic
52.7 cm x 0.2 cm x 29.7 cm
98 g
Package Content
23.8" wide
Product Material
Plastic
52.7 cm - 0.2 cm - 29.7 cm
98 g
61.1 cm x 37.5 cm x 0.5 cm / 430 g
Display Filter
Privacy Protection
2-way
Installation Type
Aspect Ratio
16:9
Surface Finish
Glossy/matte
Scratch Resistant
Mounting Kit
Included
Antimicrobial finish, fingerprint-resistant coating, +/- 30° visible angle, blue light reduction, dust protection
RoHS
GKNJ StarTech.com 19in. Monitor Privacy Screen In Stock £49.06
GKNJ StarTech.com 18.5in. Monitor Privacy Screen In Stock £47.82
GKNJ StarTech.com 20in. Monitor Privacy Screen In Stock £53.54
GKNJ StarTech.com 22in. Monitor Privacy Screen In Stock £59.05
GKNJ StarTech.com 23in. Monitor Privacy Screen In Stock £61.09
GKNJ StarTech.com 24in. Monitor Privacy Screen In Stock £66.47
GKNJ StarTech.com Privacy Screen Adhesive Strips In Stock £6.33
GKNJ StarTech.com 17" Monitor Privacy Filter In Stock £9.01
GKNJ StarTech.com 19" Monitor Privacy Filter In Stock £48.19
GKNJ StarTech.com 19.5" Monitor Privacy Filter In Stock £49.05
GKNJ StarTech.com 22" Monitor Privacy Filter In Stock £57.68
GKNJ StarTech.com 23.6" Monitor Privacy Filter In Stock £61.87
GKNJ StarTech.com 28" Monitor Privacy Filter In Stock £85.94
GKNJ StarTech.com 23.8-inch Gold Privacy Screen In Stock £67.75
GKNJ StarTech.com 24-inch Gold Privacy Screen In Stock £70.93
GKNJ StarTech.com 24-inch Gold Privacy Screen In Stock £70.29
GKNJ StarTech.com 27-inch Gold Privacy Screen In Stock £92.20
GKNJ StarTech.com 23.8" Monitor Privacy Screen In Stock £79.41
