StarTech.com 23.8" Monitor Privacy Screen
Quicklinx: HQ2RWS00 Mfr#: 238A-PRIVACY-SCREEN
Hurry, only 1 left in stock!
£79.86 ex VAT
£95.83 inc VAT
Hang this universal 23.8" 16:9 aspect ratio Monitor Privacy Screen on the top edge of a 23.8" monitor to obscure the view of sensitive on-screen information. Silicone bumpers ensure a secure and damage-free application.
  • Enhanced privacy
    Equipped with microlouver privacy technology, the StarTech.com 23.8-inch Monitor Privacy Screen ensures your data remains confidential, offering privacy protection that limits the viewing angle to +/- 30°. Ideal for maintaining screen privacy in high traffic areas or open office environments.
  • Durable design
    This privacy screen is not only removable but also features a scratch-resistant and fingerprint-resistant coating, ensuring your screen stays clear and readable, while the glossy surface finish enhances clarity and viewing comfort.
  • Easy installation
    With a plug-in type installation and hanging hooks included, setting up the StarTech.com privacy screen is hassle-free, making it a perfect fit for busy professionals and anyone looking for a quick and easy way to secure their screen's visibility.
StarTech.com 23.8-inch 16:9 Monitor Privacy Screen, Hanging Filter/Shield - display privacy filter - 23.8" wide
Display privacy filter - 2-way
Installation Type
Removable - plug-in
Package Content
Wiping cloth, 6 silicone bumpers
Display Screen Size Compatibility
23.8" wide
Product Material
Acrylic
31.6 cm x 54.3 cm x 2.3 cm
500 g
Package Content
23.8" wide
Product Material
Acrylic
31.6 cm - 54.3 cm - 2.3 cm
500 g
38.9 cm x 60.2 cm x 4 cm / 1.1 kg
Display Filter
Privacy Protection
2-way
Installation Type
Removable - plug-in
Aspect Ratio
16:9
Surface Finish
Glossy
Scratch Resistant
+/- 30° visible angle, horizontal orientation, hanging hook, microlouver privacy technology, fingerprint-resistant coating, 65% light transmittance
