StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters
Quicklinx: BWGCWS00 Mfr#: RK2236BKF
Width (mm): 60cm
Depth (mm): 90cm
£514.25 ex VAT
£617.10 inc VAT
Store your servers, network and telecommunications equipment securely in this 22U solid steel rack. The RK2236BKF 22U 36in Knock-Down Server Rack Cabinet with Casters features a vented glass front door and mesh rear door that provide devices stored in the cabinet with energy and cost-efficient passive cooling.
Supporting a total load capacity of 800 kgs (1760 lbs), the server rack is constructed of steel and aluminum to provide a sturdy platform for valuable server/networking equipment. The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps minimize shipping costs.
  • Save money, with a cost effective, compact shipping container
    The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
StarTech.com 22U Server Rack Cabinet with secure locking door - 4 Post Adjustable Depth (5.5" to 28.7") - 1768 lb capacity - 19 inch Portable Network Equipment Enclosure on wheels/casters (RK2236BKF) - rack - 22U
Rack
Height (Rack Units)
22U
Product Material
Aluminium, steel
60 cm x 90 cm x 111 cm
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, UNISLDSHF19
Rack
Product Material
Aluminium, steel
Height (Rack Units)
22U
60 cm
90 cm
111 cm
Limited warranty: - lifetime
BWGC StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
BWGC StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £41.63
BWGC StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
BWGC StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
BWGC StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.46
BWGC StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
BWGC StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
BWGC StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
BWGC StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
BWGC StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
BWGC StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
BWGC StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
BWGC StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
BWGC StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £26.48
BWGC StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £133.04
BWGC StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £91.54
BWGC StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
BWGC StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
BWGC StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
BWGC StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
BWGC StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
BWGC StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £100.69
BWGC StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
BWGC StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
BWGC StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
BWGC StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £363.55
BWGC StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
BWGC StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £74.28
BWGC StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
BWGC StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
BWGC StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
BWGC StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
BWGC StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
BWGC StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
BWGC StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.68
BWGC StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
BWGC StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
BWGC StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £158.72
BWGC StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £162.18
BWGC StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
BWGC StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.48
BWGC StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
BWGC StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
BWGC StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
BWGC StarTech.com Portable Server Rack - 9U In Stock £267.95
BWGC StarTech.com 25U 36in Server Rack Cabinet In Stock £730.55
BWGC StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
BWGC StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
BWGC StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
BWGC StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
BWGC StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
BWGC StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
BWGC StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
BWGC StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
BWGC StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
BWGC StarTech.com 19in Cable Management Panel In Stock £24.18
BWGC StarTech.com 2-Post Desktop Rack - 8U In Stock £35.14
BWGC StarTech.com 18U Server Rack Enclosure In Stock £379.01
BWGC StarTech.com 6U Wall-Mount Rack Cabinet In Stock £152.72
BWGC StarTech.com 26U Server Rack Enclosure In Stock £475.05
BWGC StarTech.com 9U Wall-Mount Rack Cabinet In Stock £178.89
BWGC StarTech.com 9U Wall-Mount Rack Cabinet In Stock £198.84
BWGC StarTech.com 12U Server Rack Enclosure In Stock £338.60
BWGC StarTech.com 12U Server Rack Enclosure In Stock £283.26
BWGC StarTech.com 15U Server Rack Enclosure In Stock £336.37
BWGC StarTech.com 12U Server Rack Enclosure In Stock £385.18
BWGC StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £29.04
BWGC StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £435.23
BWGC StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £480.37
BWGC StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.77
BWGC StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
BWGC StarTech.com 42U Server Rack Cabinet In Stock £1,258.59
Width (mm): 60cm
Depth (mm): 90cm
Price Range Ex VAT: £500 - £750
