StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters
Quicklinx: BWGCWS00 Mfr#: RK2236BKF
Width (mm): 60cm
Depth (mm): 90cm
Hurry, only 3 left in stock!
£501.70 ex VAT
£602.04 inc VAT
Store your servers, network and telecommunications equipment securely in this 22U solid steel rack. The RK2236BKF 22U 36in Knock-Down Server Rack Cabinet with Casters features a vented glass front door and mesh rear door that provide devices stored in the cabinet with energy and cost-efficient passive cooling.
Supporting a total load capacity of 800 kgs (1760 lbs), the server rack is constructed of steel and aluminum to provide a sturdy platform for valuable server/networking equipment. The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps minimize shipping costs.
  • Save money, with a cost effective, compact shipping container
    The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
StarTech.com 22U Server Rack Cabinet with secure locking door - 4 Post Adjustable Depth (5.5" to 28.7") - 1768 lb capacity - 19 inch Portable Network Equipment Enclosure on wheels/casters (RK2236BKF) - rack - 22U
Rack
Height (Rack Units)
22U
Product Material
Aluminium, steel
60 cm x 90 cm x 111 cm
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, UNISLDSHF19
Rack
Product Material
Aluminium, steel
Height (Rack Units)
22U
60 cm
90 cm
111 cm
Limited warranty: - lifetime
BWGC StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £253.47
BWGC StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £92.31
BWGC StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £40.61
BWGC StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £66.84
BWGC StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £44.03
BWGC StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £76.96
BWGC StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
BWGC StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
BWGC StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.44
BWGC StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £452.75
BWGC StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.09
BWGC StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
BWGC StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
BWGC StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
BWGC StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.06
BWGC StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £129.80
BWGC StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £89.04
BWGC StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £514.22
BWGC StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £273.74
BWGC StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £309.46
BWGC StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £600.89
BWGC StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £84.75
BWGC StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £61.35
BWGC StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £70.88
BWGC StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £75.13
BWGC StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £353.02
BWGC StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £17.22
BWGC StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £71.34
BWGC StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £79.75
BWGC StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
BWGC StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.20
BWGC StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £36.09
BWGC StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £50.11
BWGC StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
BWGC StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.23
BWGC StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.20
BWGC StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.24
BWGC StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £154.86
BWGC StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £157.73
BWGC StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
BWGC StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.41
BWGC StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £22.90
BWGC StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £55.20
BWGC StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
BWGC StarTech.com Portable Server Rack - 9U In Stock £261.41
BWGC StarTech.com 25U 36in Server Rack Cabinet In Stock £712.74
BWGC StarTech.com 100 Pkg M5 Cage Nuts In Stock £25.96
BWGC StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
BWGC StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
BWGC StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
BWGC StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
BWGC StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
BWGC StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
BWGC StarTech.com 100 Pkg M5 Mounting Screws In Stock £28.96
BWGC StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
BWGC StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.90
BWGC StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.45
BWGC StarTech.com 19in Cable Management Panel In Stock £23.58
BWGC StarTech.com 2-Post Desktop Rack - 8U In Stock £34.28
BWGC StarTech.com 18U Server Rack Enclosure In Stock £369.77
BWGC StarTech.com 6U Wall-Mount Rack Cabinet In Stock £148.99
BWGC StarTech.com 26U Server Rack Enclosure In Stock £463.46
BWGC StarTech.com 9U Wall-Mount Rack Cabinet In Stock £174.53
BWGC StarTech.com 9U Wall-Mount Rack Cabinet In Stock £193.99
BWGC StarTech.com 12U Server Rack Enclosure In Stock £330.35
BWGC StarTech.com 12U Server Rack Enclosure In Stock £280.72
BWGC StarTech.com 15U Server Rack Enclosure In Stock £313.10
BWGC StarTech.com 12U Server Rack Enclosure In Stock £375.79
BWGC StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £424.62
BWGC StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £468.65
BWGC StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.53
BWGC StarTech.com M6 Mounting Screws 50Pack In Stock £16.79
BWGC StarTech.com 42U Server Rack Cabinet In Stock £1,227.89
Width (mm): 60cm
Depth (mm): 90cm
Price Range Ex VAT: £500 - £750
