Brand
StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters
Quicklinx: BWGCWS00 Mfr#: RK2236BKF
Width (mm): 60cm
Depth (mm): 90cm
Hurry, only 1 left in stock!
£585.14 ex VAT
£702.16 inc VAT
Store your servers, network and telecommunications equipment securely in this 22U solid steel rack. The RK2236BKF 22U 36in Knock-Down Server Rack Cabinet with Casters features a vented glass front door and mesh rear door that provide devices stored in the cabinet with energy and cost-efficient passive cooling.
Supporting a total load capacity of 800 kgs (1760 lbs), the server rack is constructed of steel and aluminum to provide a sturdy platform for valuable server/networking equipment. The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps minimize shipping costs.
StarTech.com 22U Server Rack Cabinet on Wheels - 36 inch Adjustable Depth - Portable Network Equipment Enclosure (RK2236BKF) - rack - 22U
Rack
Height (Rack Units)
22U
Product Material
Aluminium, steel
60 cm x 90 cm x 111 cm
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, UNISLDSHF19
Rack
Product Material
Aluminium, steel
Height (Rack Units)
22U
60 cm
90 cm
111 cm
Limited warranty - lifetime
BWGC StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £458.02
BWGC StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £15.93
BWGC StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £78.55
BWGC StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £73.33
BWGC StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £41.48
BWGC StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £82.96
BWGC StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.84
BWGC StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £33.51
BWGC StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £33.13
BWGC StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £515.27
BWGC StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £314.93
BWGC StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.36
BWGC StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.08
BWGC StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £63.16
BWGC StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.48
BWGC StarTech.com Universal Swivel VESA LCD Mounting Bracket for 19in Rack or Cabinet In Stock £68.08
BWGC StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £92.70
BWGC StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £502.21
BWGC StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £273.04
BWGC StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £614.19
BWGC StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.48
BWGC StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £103.59
BWGC StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £58.10
BWGC StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £75.75
BWGC StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £80.91
BWGC StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £36.22
BWGC StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £72.65
BWGC StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £86.88
BWGC StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £34.10
BWGC StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x5.9in (5.7x15cm) In Stock £4.79
BWGC StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £3.35
BWGC StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.01
BWGC StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £36.86
BWGC StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £157.49
BWGC StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £164.95
BWGC StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £42.43
BWGC StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £19.21
BWGC StarTech.com 2U Hinged/Vented Rack Panel In Stock £20.05
BWGC StarTech.com 2U Double-Sided Horizontal Cable Management Panel with Finger Duct & D-Ring Hooks In Stock £45.30
BWGC StarTech.com 2U Hinged & Vented Blank Rack Panel In Stock £18.63
BWGC StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.94
BWGC StarTech.com 4U Blank Panel with Hinge In Stock £23.31
BWGC StarTech.com 4U Vented Panel with Hinge In Stock £29.58
BWGC StarTech.com 1U Server Rack Panel In Stock £12.19
BWGC StarTech.com 2U Server Rack Panel In Stock £14.04
BWGC StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £63.56
BWGC StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £32.14
BWGC StarTech.com Portable Server Rack - 9U In Stock £253.32
BWGC StarTech.com 50 Pkg M6 Cage Nuts In Stock £21.23
BWGC StarTech.com 100 Pkg M5 Cage Nuts In Stock £33.34
BWGC StarTech.com 50 Pkg M5 Cage Nuts In Stock £14.75
BWGC StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £57.05
BWGC StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £31.71
BWGC StarTech.com 50 Pkg M5 Mounting Screws In Stock £17.89
BWGC StarTech.com 100 Pkg M5 Mounting Screws In Stock £33.69
BWGC StarTech.com 50 Pkg M6 Mounting Screws In Stock £18.70
BWGC StarTech.com 100 Pkg M6 Cage Nuts In Stock £29.13
BWGC StarTech.com 19in Cable Management Panel In Stock £23.15
BWGC StarTech.com 18U Server Rack Enclosure In Stock £393.33
BWGC StarTech.com 6U Wall-Mount Rack Cabinet In Stock £166.55
BWGC StarTech.com 26U Server Rack Enclosure In Stock £490.84
BWGC StarTech.com 12U Server Rack Enclosure In Stock £281.12
BWGC StarTech.com 12U Server Rack Enclosure In Stock £307.65
BWGC StarTech.com 12U Server Rack Enclosure In Stock £367.66
BWGC StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £498.74
BWGC StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £527.27
Width (mm): 60cm
Depth (mm): 90cm
Price Range Ex VAT: £500 - £750
Stock Status: In stock
