StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters
Quicklinx: BWGCWS00 Mfr#: RK2236BKF
Depth (mm): 90cm
Width (mm): 60cm
Hurry, only 1 left in stock!
£524.85 ex VAT
£629.82 inc VAT
Store your servers, network and telecommunications equipment securely in this 22U solid steel rack. The RK2236BKF 22U 36in Knock-Down Server Rack Cabinet with Casters features a vented glass front door and mesh rear door that provide devices stored in the cabinet with energy and cost-efficient passive cooling.
Supporting a total load capacity of 800 kgs (1760 lbs), the server rack is constructed of steel and aluminum to provide a sturdy platform for valuable server/networking equipment. The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps minimize shipping costs.
  • Save money, with a cost effective, compact shipping container
    The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
StarTech.com 22U Server Rack Cabinet with secure locking door - 4 Post Adjustable Depth (5.5" to 28.7") - 1768 lb capacity - 19 inch Portable Network Equipment Enclosure on wheels/casters (RK2236BKF) - rack - 22U
Rack
Height (Rack Units)
22U
Product Material
Aluminium, steel
60 cm x 90 cm x 111 cm
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, UNISLDSHF19
Rack
Product Material
Aluminium, steel
Height (Rack Units)
22U
60 cm
90 cm
111 cm
Limited warranty: - lifetime
BWGC StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £96.93
BWGC StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £43.54
BWGC StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £71.67
BWGC StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
BWGC StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.46
BWGC StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
BWGC StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £32.14
BWGC StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £473.62
BWGC StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
BWGC StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.75
BWGC StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
BWGC StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
BWGC StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £26.48
BWGC StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £144.10
BWGC StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £91.54
BWGC StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £287.42
BWGC StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £323.73
BWGC StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
BWGC StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £91.50
BWGC StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £100.69
BWGC StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £65.78
BWGC StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £78.70
BWGC StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £80.56
BWGC StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £363.55
BWGC StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £74.28
BWGC StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £83.04
BWGC StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £46.33
BWGC StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
BWGC StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £55.64
BWGC StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.68
BWGC StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £40.38
BWGC StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £162.59
BWGC StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £162.18
BWGC StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £49.33
BWGC StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £18.29
BWGC StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £24.18
BWGC StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £61.28
BWGC StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
BWGC StarTech.com Portable Server Rack - 9U In Stock £274.48
BWGC StarTech.com 25U 36in Server Rack Cabinet In Stock £745.62
BWGC StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £58.00
BWGC StarTech.com 100 Pkg M5 Mounting Screws In Stock £31.28
BWGC StarTech.com 19in Cable Management Panel In Stock £24.18
BWGC StarTech.com 2-Post Desktop Rack - 8U In Stock £38.07
BWGC StarTech.com 18U Server Rack Enclosure In Stock £410.50
BWGC StarTech.com 6U Wall-Mount Rack Cabinet In Stock £156.45
BWGC StarTech.com 26U Server Rack Enclosure In Stock £484.85
BWGC StarTech.com 9U Wall-Mount Rack Cabinet In Stock £183.25
BWGC StarTech.com 9U Wall-Mount Rack Cabinet In Stock £203.68
BWGC StarTech.com 12U Server Rack Enclosure In Stock £345.58
BWGC StarTech.com 12U Server Rack Enclosure In Stock £289.11
BWGC StarTech.com 15U Server Rack Enclosure In Stock £327.55
BWGC StarTech.com 12U Server Rack Enclosure In Stock £393.13
BWGC StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £30.39
BWGC StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £444.21
BWGC StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £490.27
BWGC StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £28.21
BWGC StarTech.com 42U Server Rack Cabinet In Stock £1,284.53
Depth (mm): 90cm
Width (mm): 60cm
Price Range Ex VAT: £500 - £750
