StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf
Quicklinx: 7P2CWS00 Mfr#: SLIDESHELFD
Product Type: Rack keyboard shelf
12 In Stock
£92.51 ex VAT
£111.01 inc VAT
Add a sturdy, sliding shelf for easy peripheral and equipment access in your server rack or cabinet. The Black SLIDESHELFD 22in Deep Sliding Server Rack Cabinet Shelf lets you add a 2-in-1 slide-shelf / keyboard tray that helps you keep costs down and productivity up. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
As your server cabinet needs change, the SLIDESHELFD changes to suit by allowing you to use it as a sturdy sliding shelf, or a 1U pull out drawer with a weight capacity of 55 pounds. Simply flip the installed drawer over and it becomes a shelf to hold monitors, laptops and other diagnostic equipment. An easy-to-hide handle pulls out to help you get a grip on the situation and hides away quickly.
The rack shelf includes all of the tools needed for installation, and is compatible with standard 19in racks and cabinets with a 22in depth, including the StarTech.com 7236CABINET, RK2236BKF, RK4236BK, and RK4236BKNS DuraRak cabinets.
  • Sturdy Material
    Made from high-quality aluminum, this keyboard shelf is designed to withstand regular use while securely supporting heavier equipment.
  • Convenient Sliding Design
    The sliding mechanism enables quick access to equipment, facilitating smoother workflow and organization in a compact space.
  • Supportive Weight Capacity
    With a capacity of 55 lbs, this shelf can accommodate a variety of devices and accessories, making it a versatile addition to your setup.
  • Includes Mounting Kit
    The included mounting kit ensures straightforward installation, allowing users to quickly integrate the shelf into their rack system.
StarTech.com 1U Sliding Server Rack Mount Keyboard Shelf Tray - 55lbs - 22" Deep Steel Pull Out Drawer for 19" AV, Network Equipment Rack (SLIDESHELFD) - rack keyboard shelf
Rack keyboard shelf
Product Material
Aluminium
44.5 cm x 55.9 cm
Sliding
P/N: 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK1536BKF, RK1833BKM, RK1836BKF, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4236BKNS, RK4242BK, RK4242BK24, RK4242BK30, RK4242BKNS, RK960CP
Rack keyboard shelf
Product Material
Aluminium
44.5 cm
55.9 cm
Mounting Kit
Included
Sliding
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1536BKF, RK1833BKM, RK1836BKF, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4236BKNS, RK4242BK, RK4242BK24, RK4242BK30, RK4242BKNS, RK960CP
7P2C StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £85.29
7P2C StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.53
7P2C StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.75
7P2C StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £26.00
7P2C StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £87.09
7P2C StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £63.29
7P2C StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.90
7P2C StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £73.91
7P2C StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £82.73
