StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy
Quicklinx: FSR4WS00 Mfr#: PRIVSCNMON21
18 in stock
£45.78 ex VAT
£54.93 inc VAT
Confidentiality Screen Filter Blue Light Reduction Matte or Glossy 2-Year Warranty. The monitor privacy screen is easy to attach and remove. Simply attach the 21.5 inch privacy screen  to your screen using the attachment strips or slide-mount tabs. This confidentiality screen filter is also reversible. The matte side provides you with glare reduction and the glossy side of the privacy screen will provide you with increased clarity.
Protect Your Privacy
The privacy screen protector for desktop monitors is a great investment if you want to protect your privacy. It is a convenient and cost-effective way to keep your classified information, intellectual property or any other important data you wish to keep protected. You can have a peace of mind while working in the office or public environments because you know your screen is protected with the 30+/- degree privacy viewing angle.
The monitor privacy filter is designed to filter blue light (390nm~480 wavelength) that can cause eye strain and can disrupt sleeping patterns.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The TAA compliant PRIVSCNMON21 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Protect sensitive data
    This monitor security filter provides privacy outside +/-30° viewing angle from the center of your 16:9 27" widescreen display, keeping data on your desktop screen confidential.
  • Easy application
    Using adhesive strips that won't leave permanent residue, apply the removable privacy filter cover to monitor bezel with the side mount tabs or directly to the screen for extended use.
  • Blue light reduction
    In addition to protecting your data, this PC monitor privacy screen minimizes digital eye strain when working for extended periods of time by reducing blue light by 30% to 40%.
  • Durable & easy to clean
    Flexible dual mounting options fit various monitor bezels to add a durable computer screen protector film to the monitor to protect from scratches, fingerprints & dust.
  • Reduce glare or increase clarity
    Reversible computer monitor privacy filter retains sharp and consistent image quality in any lighting with an anti-glare matte-finish or a high-clarity glossy-finish.
StarTech.com Monitor Privacy Screen for 21 inch PC Display, Computer Screen Security Filter, Blue Light Reducing Screen Protector Film, 16:9 Widescreen, Matte/Glossy, +/-30 Degree Viewing - Blue Light Filter (PRIVSCNMON21) - display privacy filter - 21.5" wide - TAA Compliant
Display privacy filter
Package Content
Adhesive strips, slide mount tabs
Transparent
Display Screen Size Compatibility
21.5" wide
Product Material
Plastic
26.77 cm x 47.6 cm x 0.2 cm
195 g
TAA Compliant
P/N: ARMUNONB1
Package Content
21.5" wide
Product Material
Plastic
26.77 cm - 47.6 cm - 0.2 cm
195 g
37 cm x 57 cm x 0.4 cm / 200 g
Transparent
Display Filter
Aspect Ratio
16:9
Mounting Kit
Included
Anti-glare, matte, glossy surface, +/- 30° visible angle, blue light reduction
RoHS, REACH, GSA
TAA Compliant
P/N: ARMUNONB1
FSR4 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £53.58
FSR4 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £64.66
FSR4 StarTech.com 22in. Monitor Privacy Screen In Stock £59.64
FSR4 StarTech.com 23in. Monitor Privacy Screen In Stock £62.22
FSR4 StarTech.com 24in. Monitor Privacy Screen In Stock £80.51
Stock Status: In stock
