StarTech.com 20m LC/LC OM5 Fiber Cable
Quicklinx: HHX5WS00 Mfr#: LCLCL-20M-OM5-FIBER
Length: 20m
Colour: Green
11 In Stock
£67.49 ex VAT
£80.98 inc VAT
OM5 FIBER CABLE: The OM5 LOMMF cable is optimized for 40/100 Gbps fiber optic networks. Extended 850-953 nm wavelength support enables SWDM (Short Wavelength Division Multiplexing) for greater channel isolation.
QUALITY CONSTRUCTION: LC/LC-UPC ends for better return loss than PC polishing - Color-coded connectors for polarity - Fiber core insensitive to bending, Aramid sheathing for a maggione bend radius.
RELIABLE: individually tested for guaranteed performance (testing included). LSZH sheathing emits low toxic fumes in case of combustion. Safe in poorly ventilated spaces. Attenuation value <2.4 dB/km meets/exceeds standards.
WIDE COMPATIBILITY: OM5 multimode cable supports 10/40/100G networks, compatible with OM4/OM3. High resistance to microbending facilitates bending in complex installations, ideal for fiber switches/servers, SANs and SFP+/QSFP+/QSFP28 modules.
SPECIFICATIONS: OM5 - LC/LC (UPC) - 50/125µm - 850-953nm VCSEL/1300nm LED - Modal bandwidth: 4700MHz.km (850nm), 2470MHz.km (953nm) - Insertion loss: =0.3dB - Return loss: =30dB - Cable Ø: 2.9mm - Bend radius: 3-6cm
  • High-speed connectivity
    Experience fast data transfer rates of up to 100 Gbps, ideal for high-bandwidth applications and efficient data center operations.
  • Enhanced durability
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion, ensuring a safer environment for all.
  • Optimized for laser
    Leveraging Laser-optimized multimode fiber (LOMMF) with a wavelength range of 840/953/1300 nm, this cable is engineered for superior performance in VCSEL-based systems.
  • Bend insensitive design
    Crafted to maintain signal integrity even when bent or twisted, this cable ensures consistent and reliable connectivity in tight spaces and challenging installations.
  • Eco-friendly choice
    Halogen-free construction not only enhances safety by reducing hazardous emissions but also underscores our commitment to environmental sustainability.
StarTech.com 20m (65ft) LC to LC (UPC) OM5 Multimode Fiber Optic Cable, 50/125µm Duplex LOMMF Zipcord, VCSEL, 40G/100G, Bend Insensitive, Low Insertion Loss, LSZH Fiber Patch Cord - patch cable - 20 m - green
Patch cable - OM5
Duplex fibre optic
Type of Fibre Optics
Multimode
Halogen-free, up to 100 Gbps data transfer rate, Laser-optimized multimode fibre (LOMMF), wavelength of 840/953/1300 nm
Length
20 m
Diameter
2.9 mm
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC/UPC multi-mode - male
Connector (Second End)
Green
Network Cable Type
Patch cable - OM5
Duplex fibre optic
Multimode
Jacket Material
50 / 125 micron
Length
20 m
Diameter
2.9 mm
Green
Connector
RoHS
Shipping Width
33 cm
Shipping Depth
25 cm
Shipping Height
4.1 cm
Shipping Weight
156 g
-20 °C
60 °C
HHX5 StarTech.com 15m LC/LC OM5 Fiber Cable In Stock £55.00
HHX5 StarTech.com 1m LC/LC OM5 Fiber Cable In Stock £17.35
HHX5 StarTech.com 2m LC/LC OM5 Fiber Cable In Stock £19.09
HHX5 StarTech.com 3m LC/LC OM5 Fiber Cable In Stock £23.93
HHX5 StarTech.com 5m LC/LC OM5 Fiber Cable In Stock £28.27
HHX5 StarTech.com 7m LC/LC OM5 Fiber Cable In Stock £33.91
Length: 20m
Colour: Green
