StarTech.com 20m Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P0GWS00 Mfr#: MXTMMHQ20M
Length: 20m
£49.74 ex VAT
£59.68 inc VAT
Connect your VGA monitor with the highest quality connection available. This 20-meter high resolution VGA monitor cable is designed to provide the highest video quality possible through a VGA connection.
Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 20m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 20 m
VGA cable
Triple shielded twisted pair coaxial
Molded
Length
20 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Molded
Length
20 m
Connector
RoHS
7P0G StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.07
7P0G StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £7.06
7P0G StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £29.43
7P0G StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £47.38
7P0G StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £8.25
7P0G StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £10.46
Length: 20m
