StarTech.com 20m (65ft) Active HDMI Cable
Quicklinx: C53MWS00 Mfr#: HDMM20MA
Length: 20m
More than 50 In Stock
£77.66 ex VAT
£93.19 inc VAT
Connect your HDMI devices, up to 20m away with no signal loss. This active HDMI cable offers a connection distance of up to 65 feet (20 meters) between your HDMI enabled devices. It meets CL2 rating safety requirements, so it's ideal for in-wall cable runs in your home and office installations.
The cable features built-in amplifier circuitry which actively boosts your HDMI signal, with no external power required. It's the perfect solution for longer transmissions without any signal loss.
The HDMI cable is CL2 rated for in-wall installations, which makes them perfect for A/V installations in residential or office settings. You can set up your home theater, gaming or audio-video equipment with the cables hidden away safely inside the walls and place your devices as needed throughout your work or living space.
This high-quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high-definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
This cable features unidirectional architecture which requires that the cable is installed in the correct direction. Please refer to the Source and Display labels on the HDMI connectors in order to ensure that the device and the HDMI source are connected properly.
  • Reliable connectivity
    This HDMI cable features a double shielded design that helps minimize interference and ensures the integrity of the signal over long distances.
  • Active signal regeneration
    The active cable technology allows for seamless transmission of high-quality signals, making it suitable for high-definition video and audio applications.
  • Durable construction
    Constructed with gold plated connectors, this cable offers resistance to corrosion and wear, ensuring a longer lifespan and consistent performance.
StarTech.com 65 ft (20m) High Speed HDMI Cable - Male to Male - Active - 28AWG - CL2 Rated In-wall Installation - Ultra HD 4K x 2K - Active HDMI Cable (HDMM20MA) - HDMI cable - 20 m
Cable
HDMI cable
Double shielded
Length
20 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Active cable (signal regeneration)
Cable Type
HDMI cable
Double shielded
Jacket Material
PVC
Shielding Material
Length
20 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
FCC, RoHS
C53M StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
C53M StarTech.com 30m 100ft Active HDMI Cable In Stock £122.57
C53M StarTech.com 20m (65ft) Active HDMI Cable In Stock £77.66
Length: 20m
