StarTech.com 20in Slimline SATA Extension Cable
Quicklinx: 6BCBWS00 Mfr#: SLSATA20EXT
Length: 50.8cm
£11.46 ex VAT
£13.75 inc VAT
Extend Slimline SATA power and data connections by up to 20 inches. The SLSATA20EXT Slimline SATA Extension Cable features one Slimline SATA male connector and one Slimline SATA female connector, allowing you to extend the distance/placement of slim SATA drives within a tower style computer case by 20in - in turn making it easier to position your Slimline capable peripherals (drives etc.) as needed.
Constructed of only top quality materials and designed for optimum performance and reliability the SLSATA20EXT supports full SATA 3.0 bandwidth (up to 6 Gbps) when used with SATA 3.0 compliant drives.
StarTech.com Slimline SATA Extension Cable - SATA extension cable - Serial ATA 150/300 - Slimline SATA (M) to Slimline SATA (F) - 1.7 ft - red - SLSATA20EXT - SATA extension cable - 50.8 cm
Interface Speed
Serial ATA 150/300
Length
50.8 cm
Connector
13 pin Slimline Serial ATA - male
Connector (Second End)
13 pin Slimline Serial ATA - female
Red
Storage Cable Type
Interface Speed
Serial ATA 150/300
Length
50.8 cm
Red
Connector
RoHS
Length: 50.8cm
Stock Status: In stock
