Install Slimline drives into systems with standard SATA controllers. The SLSATAF20RA Right-Angle Slimline SATA to SATA with LP4 Power Cable (20-inch) features a SATA data receptacle and a Molex (LP4) power connection on one end, and a right-angle Slimline Serial ATA receptacle on the other - enabling you to connect a slim SATA drive to a computer motherboard that does not have a Slimline connection available.
Plus, the right-angled Slimline SATA connector allows for connectivity in narrow spaces, enabling installation of the drive as needed within the system case.
Constructed of only top quality materials and designed for optimum performance and reliability the SLSATAF20RA supports full SATA 3.0 bandwidth (up to 6 Gbps) when used with SATA 3.0 compliant drives.
- StarTech.com Right Angle Slimline SATA Female to SATA w/ LP4 Power Cable - SATA cable - 50.8 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Length
- 50.8 cm
- Connectors
- 13 pin Slimline Serial ATA - female
- Connectors (Second End)
- 7 pin Serial ATA - female , 4 pin internal power (12V) - male
- Red
- Limited lifetime warranty
- Storage Cable Type
- SATA cable
- Interface Speed
- American Wire Gauge (AWG)
- 26
- Length
- 50.8 cm
- Red
- Connectors
- RoHS
