StarTech.com 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Fiber Media Converter
Quicklinx: 8GTKWS00 Mfr#: ETCHS2U
Add an un-managed, 20-slot media converter chassis to your rack or cabinet. The ETCHS2U 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Media Converters lets you add an un-managed, 20-slot media converter chassis to your rack or cabinet to provide central power and cooling.
The media converter rack includes a single 200W power supply to centrally power all 20 slots, with an additional slot to add a redundant power supply for maximum up-time. It also includes two cooling fans (one per side) to help extend the life of your media converters.
A perfect accessory to the StarTech.com ET series 2 converters, the 2U chassis is designed so that all critical components (Power, Fans and Media Converter Cards) are hot swappable to avoid network disruption.
StarTech.com 20-Slot 2U Rack Mount Media Converter Chassis for ET Series 2 Fiber Media Converters (ETCHS2U) - modular expansion base
Modular expansion base
Rack-mountable - 2U
North America, United Kingdom, Europe
Power Redundancy
Optional
43.8 cm x 30.3 cm x 8.8 cm
5 kg
P/N: ET1000S40LC2, ET90110SC2, ET90110SM302, ET90110ST2, ET90110WDM2, ET91000LC2, ET91000LCOAM, ET91000SC2, ET91000SFP2, ET91000SFP2C, ET91000SM402
Height (Rack Units)
2U
Installed Modules Qty (Max)
0 (20)
43.8 cm
30.3 cm
8.8 cm
5 kg
Enclosure Colour
Rack-mountable
Wired
Expansion Slots
20 (total) / 20 (free) x expansion slot
MTBF
65,000 hours
UL, FCC, RoHS
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
60 Watt
Power Provided
200 Watt
60 °C
5 - 90% (non-condensing)
8GTK StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter ST 2 km In Stock £70.34
8GTK StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m In Stock £150.73
8GTK StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps In Stock £148.89
8GTK StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps In Stock £316.48
8GTK StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter SC 2 km In Stock £71.49
