The DISPLPORT20L 20ft DisplayPort cable supports a maximum bandwidth of 10.8 Gbps, and is capable of providing higher performance than either HDMI or dual link DVI and supporting next generation multimedia applications with a maximum resolution capability of up to WQXGA (2560×1600).
The cable features small, USB-sized latching connectors, with support for 2-way display connectivity and optional audio support. This 20-foot DisplayPort cable is both HDCP and DPCP capable, ensuring that digitally protected content is displayed properly on the connected display.
- StarTech.com 20 ft DisplayPort Cable with Latches - 2560 x 1600 - DPCP & HDCP - Male to Male DP Video Monitor Cable (DISPLPORT20L) - DisplayPort cable - 6.1 m
- DisplayPort cable
- Technology
- Shielded
- Latched, molded
- Length
- 6.1 m
- Connector
- DisplayPort - male
- Connector (Second End)
- RoHS, NEC-CMG
- Black
- Limited lifetime warranty
- Designed For
- P/N: USB32DPPRO
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 26
- Plated Connector
- Nickel
- Latched, molded
- Length
- 6.1 m
- Black
- Connector
- 20 pin DisplayPort - male
- RoHS, NEC-CMG
- Designed For
- P/N: USB32DPPRO
