StarTech.com 20 ft DisplayPort Cable with Latches - M/M
Quicklinx: 7NXGWS00 Mfr#: DISPLPORT20L
The DISPLPORT20L 20ft DisplayPort cable supports a maximum bandwidth of 10.8 Gbps, and is capable of providing higher performance than either HDMI or dual link DVI and supporting next generation multimedia applications with a maximum resolution capability of up to WQXGA (2560×1600).
The cable features small, USB-sized latching connectors, with support for 2-way display connectivity and optional audio support. This 20-foot DisplayPort cable is both HDCP and DPCP capable, ensuring that digitally protected content is displayed properly on the connected display.
StarTech.com 20 ft DisplayPort Cable with Latches - 2560 x 1600 - DPCP & HDCP - Male to Male DP Video Monitor Cable (DISPLPORT20L) - DisplayPort cable - 6.1 m
DisplayPort cable
Shielded
Latched, molded
Length
6.1 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS, NEC-CMG
P/N: USB32DPPRO
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
26
Plated Connector
Nickel
Latched, molded
Length
6.1 m
Connector
20 pin DisplayPort - male
RoHS, NEC-CMG
P/N: USB32DPPRO
7NXG StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
