20 Bits, H4x28mm - Soft Case - Magnetizer/Demagnitizer
This cord-less screwdriver is the ideal tool to dismantle and reassemble electronic devices during repairs. The battery powered driver set includes a precision electric screwdriver (2 x AAA batteries included), 20 micro bits, and a magnetizer/demagnetizer, housed in a durable soft carrying case. The bits included have been specially selected for compatibility with most major brands of smartphones, tablets and laptops including but not limited to Apple iPhones, iPads, Macbooks, Samsung Galaxy, HP and Acer Chromebooks, Lenovo ThinkPads.
Precision Electric Driver with LED Work Light and Forward/Reverse Modes
The premium electric driver included with this kit has several features designed for hassle-free repairs.
A built-in LED work light illuminates the area that the driver is operating in, ensuring you can clearly see shadowless details, regardless of the lighting in your repair area.
Battery operated forward and reverse modes with 0.25 to 0.35 N.m of torque, ensures you can effortlessly install and remove screws without the wrist strain that comes with manual drivers.
The included magnetizer/demagnetizer gives you the option to magnetize the driver to ensure screws are easy to install/remove without losing them. Plus, the head can be demagnetized for IT repairs on devices that may be sensitive to magnets.
Quick changing batteries ensure uninterrupted operation.
20 Specially Selected Micro Bits
This kit features 20x4mm bits specially selected for extensive compatibility with major brands of smartphones, tablets and laptop computers. Bits Included:
Philips (crosshead): PH000, PH00, PH0, PH1
Slot (flathead): SL1.0, SL1.5, SL2.0
Torx: T5
Torx Security: T6, T8
Hexagonal: H2.5, H3.0
Pentalobe: P20.8, P51.2, P61.5
Spanner: U3.0
Tri Wing: Y0.6, Y2.5
Triangle: 3.0
Robertson: S0
Durable Soft Carrying Case
Included with the electric driver is a durable soft carrying case.
CTK20PCEDRIVE is backed by a StarTech.com 2-year warranty with free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
Precision battery-powered driver
This portable electric precision screwdriver is the perfect tool to dismantle and assemble electronics devices. The cordless aluminum driver is battery powered; LED light, buttons for forward and reverse modes. -
Works with major devices
The bits included have been specially selected for compatibility with major brands of smartphones, tablets and laptop computers incl. but not limited to iPhone, iPad, Samsung Galaxy, Dell, HP, Acer, Lenovo ThinkPad, Macbook, Chromebook. -
Hassle-free operation
Mini power operated driver helps to prevent screw damage; quick change batteries ensure uninterrupted operation and magnetizer/demagnetizer makes this kit ideal for IT/repair shops.
- StarTech.com - electric precision screwdriver - cordless - 2 batteries
- Product Type
- Electric precision screwdriver - cordless
- Speed
- 110 rpm
- Chuck Size
- 4 mm
- Max Torque (hard)
- 0.35 N·m
- Battery Qty
- 2
- Product Type
- Speed
- 110 rpm
- Chuck Size
- 4 mm
- Max Torque (hard)
- 0.35 N·m
- Magnetic bit holder, forward/reverse rotation, LED light
- Included Qty
- 2
Carrying Case
- Case
- Included Accessories
- 20 screwdriver bits, magnetiser/demagnetiser
- Warranty
- 2 years
StarTech.com 55-Bit Electric Precision Screwdriver Set | In Stock | £62.47 |
StarTech.com 23x47in Anti Static Mat | In Stock | £43.16 |
StarTech.com 11x18in Anti Static Mat | In Stock | £24.84 |
StarTech.com Temperature/Humidity Meter | In Stock | £24.79 |
StarTech.com Handheld Sound Level Meter | In Stock | £25.95 |
