StarTech.com 20" Slim Micro USB 3.0 Cable
Quicklinx: BN4CWS00 Mfr#: USB3AU50CMLS
Length: 50cm
Hurry, only 3 left in stock!
£7.49 ex VAT
£8.98 inc VAT
Position your USB 3.0 Micro devices with less clutter and according to your configuration needs, with a thin, more flexible cable. This slim, sturdy USB 3.1 Gen 1 (5 Gbps) cable, better known as a USB 3.0 cable, lets you position Micro-USB devices on your desk without the cable getting in the way. It's thinner and more flexible than standard cables, and features a left-angled Micro-USB connector that prevents awkward bends at the connection port.
Now you can arrange your desk according to what works best for you, without worrying about the cable bending awkwardly or straining too much to make a connection. This durable, lightweight cable is roughly half the thickness of a regular USB 3.0 cable, giving you the flexibility and freedom to place your devices as needed, with minimal clutter.
This versatile cable features a left-angled connector, which offers a more natural fit at the device connection point and helps prevent unnecessary strain and damage to the port. Plus, the short 0.5 m/1.5 ft. cable length makes this an excellent solution for close-range connections and portable applications such as connecting a portable hard drive to your laptop.
Charge your mobile device in your car or sync with your laptop.
As well as being ideal for connecting to your desktop devices, this cable provides the perfect solution for charging and syncing your USB 3.0 Micro B-equipped phones and tablets.
The short cable design is just right for people on the move, for providing simple, tidy connections and it fits nicely inside your laptop or tablet carrying case.
The cable features a thin, yet sturdy connector molding, so you'll be able to connect to your phone or tablet without removing its protective case. And, the cable's left-angled Micro-USB connector lets you text, work or game on your mobile device - even while it's charging - without the cable getting in the way.
  • Efficient Data Transfer
    Experience rapid file transfers with a 5 Gbps data rate, allowing for smooth operation with USB devices.
  • Rugged Design
    The double-shielded construction helps protect the cable from interference, ensuring reliable performance.
  • Space-saving Connector
    The left-angle Micro-USB Type-B connector allows users to connect devices in tight or awkward spaces without obstruction.
  • Long-lasting Durability
    Molded ends provide additional strength and protect the connectors from wear and tear, extending the lifespan of the cable.
  • Eco-friendly Compliance
    This cable meets RoHS standards, affirming a commitment to environmentally friendly materials and manufacturing practices.
StarTech.com 0.5m 20in Slim Micro USB 3.0 Cable M/M - Left-Angle Micro-USB - USB 3.0 A to Micro B - Angled Micro USB - USB 3.1 Gen 1 5Gbps (USB3AU50CMLS) - USB cable - Micro-USB Type B to USB Type A - 50 cm
USB cable
Double shielded
Left-angled connector, molded, strain relief, 5 Gbps data rate
Length
50 cm
Connector
10 pin Micro-USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
USB cable
Double shielded
American Wire Gauge (AWG)
26/32
Plated Connector
Nickel
Length
50 cm
Connector
USB 3.0, RoHS
BN4C StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £8.06
BN4C StarTech.com 20" Slim Micro USB 3.0 Cable In Stock £7.49
Length: 50cm
