StarTech.com 20" Side Screw Locking USB C
Quicklinx: GJWWWS00 Mfr#: USB31CCSLKV50CM
Length: 50cm
£6.37 ex VAT
£7.64 inc VAT
This side screw locking USB-C 3.2/3.1 Gen 2 10Gbps cable lets you connect your USB Type-C devices for syncing, charging, and powering your devices. The USB-C cable is also compatible with Thunderbolt 3 ports, allowing you to connect and charge your USB-C devices using your Thunderbolt 3 laptop.
  • Reliable connection with screw locking USB-C
    This cable features dual locking screws that can securely connect to your USB-C peripherals and can prevent accidental disconnection from your devices such as external hard drives or docking stations. The screws are designed to fit all devices that use a standard side screw locking input, such as StarTech.com's DK31C3HPD. The knurled screws can easily be removed from the cable completely allowing it to be used as a standard USB-C cable if required.
  • Supports up to 100W (5A) with Power Delivery 3.0
    With up to 100W (5A) of power delivery, you can power and charge a USB-C laptop, such as your Apple MacBook or Microsoft Surface Book. Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
  • Deliver 8K video with DisplayPort 1.4 Alt Mode
    The cable supports 8K 30Hz video with DisplayPort 1.4 and is backward compatible to connect your docking station or laptop to a monitor that supports 4K or 1080p resolutions.
  • Charge your mobile devices
    When used with devices that support PD 3.0, this cable charges up to 20V and 5A for a maximum of 100W. It can decrease your charge time and make sure your mobile devices are ready, whenever you need them.
  • Quality build
    This cable is constructed with durable long-lasting, flexible TPE jacket and strain relief. It has been tested to withstand 4000+ bends. It is built with aluminum-mylar foil with 85% braid coverage and EMI shielding for improved signal integrity.
StarTech.com 20" 50cm Side Screw Locking USB C Cable 10Gbps, USB 3.1/3.2 Gen 2 Type-C Cable, 100W (5A) Power Delivery Charging, DP Alt Mode, Dual Screw Lock, USB-C to C Cord, Charge/Sync - Thunderbolt 3 Compatible - USB-C cable - 24 pin USB-C to 24 pin USB-C - 50 cm
USB-C cable
4K support, Power Delivery (PD) technology, 10 Gbps data rate, DisplayPort Alternate Mode support, EMI protection, outer diameter 4.8 mm
Length
50 cm
Connector
24 pin USB-C - male - straight/locking
Connector (Second End)
USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3
Black, grey
USB-C cable
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30/32
Plated Connector
Nickel
Length
50 cm
Black, grey
Connector
USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3, RoHS, WEEE
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
14 cm
Shipping Weight
85 g
GJWW StarTech.com Rugged Right Angle USB-C Cable 1m In Stock £27.51
Length: 50cm
