StarTech.com 2-to-1 RJ45 Splitter Cable Adapter - F/M
Quicklinx: 86C5WS00 Mfr#: RJ45SPLITTER
Connect two 10/100 Ethernet devices to a single Cat5/Cat5e cable drop. The RJ45SPLITTER 2-to-1 RJ45 Splitter Cable Adapter increases the number of RJ45 network connections on an RJ45 outlet, allowing two 10/100 Ethernet signals through a single Cat5/Cat5e wire.
On one end of the installation the splitter enables you to connect two patch cables from a hub or switch to a single port on a patch panel; while on the other end of the installation the splitter connects to a single Cat5/Cat5e network drop through a wall outlet which can then be split and connected to two separate devices. The patch panel and wall outlet are connected through a single Cat5/Cat5e cable.
  • Convenient network expansion
    This splitter allows the connection of multiple devices to a single network point, streamlining your network design.
  • Reliable connectivity
    Supports 10/100 Mbps network speeds, ensuring stable and efficient data transfer across connected devices.
  • Simple installation
    The ergonomic design enables easy integration into current setups, requiring minimal effort for adjustments.
  • Flexible compatibility
    Features one male and two female RJ-45 connectors, making it adaptable for various networking needs.
StarTech.com 2-to-1 RJ45 10/100 Mbps Splitter/Combiner - One adapter required at each end of the connection - network splitter
Network splitter
Connector
RJ-45 - male
Connector (Second End)
2 x RJ-45 - female
Network Cable Type
Network splitter
Connector
RJ-45 - male
2 x RJ-45 - female
