StarTech.com 2 Rack Unit Labels - Up to 49U
Quicklinx: C7CMWS00 Mfr#: RKUNITAPE
10 In Stock
£20.25 ex VAT
£24.30 inc VAT
Ensure perfect rail-to-rail alignment, when mounting equipment in your server rack with these rack unit labeling strips. These labels help you install equipment in your server rack more easily. You can add up to 49 unit markings on either side of any rack. This is perfect for adding unit measurements to server racks that don't have unit markings, or to older racks that have had their markings worn off over time.
This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
When rack unit measurements are not visible, it can make installing large equipment a hassle. You typically have to align the equipment by eye, which can lead to installing the device in different unit holes on each side of your rack, but that could cause the annoying and time-consuming task of repositioning the device after it's been installed. Using these rack labels is an inexpensive solution that ensures proper alignment and hassle-free installation.
The label strips are self-adhesive, easily attaching to the side of your rack for a simple installation. Each label in the kit contains markings for up to 49 units. This ensures that you can easily cut the label down to a smaller size and fit any rack, up to 49U in size.
  • Avoid hassle when installing rackmount equipment
  • Fast and simple application on any rack, up to 52U in size
    The label strips are self-adhesive, easily attaching to the side of your rack for a simple installation. Each label in the kit contains markings for up to 52 units. This ensures that you can easily cut the label down to a smaller size and fit any rack, up to 52U in size. The labels included in the RKUNITAPE are backed by a 2-year StarTech.com warranty and free lifetime technical support.
StarTech.com Rack Unit Labels - Server Rack Unit Alignment Strips - Up to 52U - 2-Pack (RKUNITAPE) - rack height identification labels - 49U - TAA Compliant
Rack height identification labels
Packaged Quantity
2 (specifications are for single item)
Height (Rack Units)
49U
14 g
TAA Compliant
Packaged Quantity
Height (Rack Units)
49U
14 g
TAA Compliant
Limited warranty: - 2 years
-50 °C
90 °C
