StarTech.com 2 Pt USB 3.1 + eSATA PCIe Card
Quicklinx: D9CCWS00 Mfr#: PEXUSB311A1E
Wired / Wireless: Wired
Protocol: SuperSpeed USB 3.0, USB, USB 2.0, USB 3.1
Type: USB adapter
5 in stock
£39.37 ex VAT
£47.24 inc VAT
Standard delivery Delivered within 3-5 working days
Add one USB 3.1 Gen 2 port and one eSATA (6Gbps) port to your computer, through a PCI Express slot. This combination PCI Express controller card lets you add both a USB 3.1 Gen 2 port and an eSATA port to your desktop PC, through a single PCIe slot. The versatile controller card offers a cost-effective way to add high-performance connectivity to your computer, with support for newer USB 3.1 devices as well as eSATA hard drives.
At up to 10Gbps, the USB 3.1 PCIe card delivers the speed you need for seamless performance from your compatible devices. It's also backward compatible with previous versions of USB, so you can connect your existing USB 3.0 / 2.0 / 1.1 equipment.
The controller card also connects your computer to an eSATA device, providing a hot-pluggable, high-speed storage solution for backing up or archiving data. With support for SATA I, II and III hard drives, and data transfer speeds of up to 6Gbps, the controller card offers reliable performance for your external SATA storage applications.
For added versatility, the controller card is equipped with a standard-profile bracket and includes a low-profile bracket for installation in small form-factor computers.
StarTech.com 2-Port USB 3.1 Gen 1(10Gbps) and eSATA(6Gbps) PCIe Card - PCI Express Controller Card - 1x USB-A and 1x eSATA (PEXUSB311A1E) - USB adapter - PCIe 3.0 x4 - USB 3.1 x 1 + eSATA 6 Gb/s x 1
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
Ports
12.1 cm x 9.3 cm x 2.2 cm
45.6 g
USB, USB 2.0, USB 3.0, USB 3.1
ASMedia ASM2142 / ASM1351
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
Red
Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Linux 3.5 to 4.4.x LTS versions
USB adapter
PCI Express 3.0 x4
Ports
Wired
USB, USB 2.0, SuperSpeed USB 3.0, USB 3.1
Processor / Memory
1 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x eSATA - 7 pin external Serial ATA
Low-profile bracket
FCC, RoHS
Red
12.1 cm
9.3 cm
2.2 cm
45.6 g
5 °C
50 °C
15 - 90% (non-condensing)
D9CC StarTech.com 3 ft Shielded External eSATA Cable M/M In Stock £6.92
D9CC StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £72.27
D9CC StarTech.com 7 Port PCIe USB 3.0 Card In Stock £48.82
D9CC StarTech.com 4 Port PCIe USB 3.0 Card In Stock £25.36
D9CC StarTech.com 4 Port PCIe USB 3.0 Card In Stock £23.95
D9CC StarTech.com 3 Port PCIe USB 3.0 Card + GbE In Stock £39.90
D9CC StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £24.93
D9CC StarTech.com USB 3.1 Tool-free Enclosure In Stock £21.20
D9CC StarTech.com USB 3.1 Gen 2 Enclosure In Stock £36.28
D9CC StarTech.com 2Port USB 3.1 10Gbps Card PCIe In Stock £33.61
Protocol: USB
Protocol: USB 2.0
Protocol: USB 3.1
Type: USB adapter
Price Range Ex VAT: 0 - 50
