Add one USB 3.1 Gen 2 port and one eSATA (6Gbps) port to your computer, through a PCI Express slot. This combination PCI Express controller card lets you add both a USB 3.1 Gen 2 port and an eSATA port to your desktop PC, through a single PCIe slot. The versatile controller card offers a cost-effective way to add high-performance connectivity to your computer, with support for newer USB 3.1 devices as well as eSATA hard drives.
At up to 10Gbps, the USB 3.1 PCIe card delivers the speed you need for seamless performance from your compatible devices. It's also backward compatible with previous versions of USB, so you can connect your existing USB 3.0 / 2.0 / 1.1 equipment.
The controller card also connects your computer to an eSATA device, providing a hot-pluggable, high-speed storage solution for backing up or archiving data. With support for SATA I, II and III hard drives, and data transfer speeds of up to 6Gbps, the controller card offers reliable performance for your external SATA storage applications.
For added versatility, the controller card is equipped with a standard-profile bracket and includes a low-profile bracket for installation in small form-factor computers.
Fast transfers over USB 3.2 Gen 2
At up to 10Gbps, the USB 3.2 PCIe card delivers the speed you need for seamless performance from your compatible devices. It's also backward compatible with previous versions of USB, so you can connect your existing USB 3.2 Gen 1 / 2.0 / 1.1 equipment. -
Connect to eSATA devices
The controller card also connects your computer to an eSATA device, providing a hot-pluggable, high-speed storage solution for backing up or archiving data. With support for SATA I, II and III hard drives, and data transfer speeds of up to 6Gbps, the controller card offers reliable performance for your external SATA storage applications. -
Versatile installation options
For added versatility, the controller card is equipped with a standard-profile bracket and includes a low-profile bracket for installation in small form-factor computers. The PEXUSB311A1E is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 2-Port USB 3.1 Gen 1(10Gbps) and eSATA(6Gbps) PCIe Card - PCI Express Controller Card - 1x USB-A and 1x eSATA (PEXUSB311A1E) - USB adapter - PCIe 3.0 x4 - USB 3.1 x 1 + eSATA 6 Gb/s x 1
- USB adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 3.0 x4
- Ports
- 12.1 cm x 9.3 cm x 2.2 cm
- 45.6 g
- Data Link Protocol
- USB, USB 2.0, USB 3.0, USB 3.1
- Processor
- ASMedia ASM2142 / ASM1351
- USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
- Red
- System Requirements
- Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Linux 3.5 to 4.4.x LTS versions
- 2-year warranty
- USB adapter
- Form Factor
- Ports
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0, USB 3.1
Processor / Memory
- Processor
- 1 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x eSATA - 7 pin external Serial ATA
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Red
- OS Required
- 12.1 cm
- 9.3 cm
- 2.2 cm
- 45.6 g
- Limited warranty - 2 years
- 5 °C
- 50 °C
- 15 - 90% (non-condensing)
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.58 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £84.14 |
StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £11.64 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £49.11 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £64.50 |
StarTech.com 7 Port PCIe USB 3.0 Card | In Stock | £59.25 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £28.40 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £25.01 |
StarTech.com 3 Port PCIe USB 3.0 Card + GbE | In Stock | £43.86 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.55 |
