2 Post Network Rack shelf Black 75 lb. (34 kg). The 2 post server rack shelf allows you to add a high capacity mid-mount fixed shelf to almost any standard 2 post server rack.
EIA 310 Compliant
Our 2u rack shelf is EIA 310 compliant meaning it can fit most standard 19" 2 post racks. The included mounting brackets can be adjusted to accommodate different post depths, making this center mount rack shelf a universal solution for 2 post rack storage, while the vented design helps to improve airflow in the rack.
Solid Steel Construction
Constructed using SPCC commercial grade cold-rolled steel, this durable 2 post network rack shelf can hold up to 75 lb. (34 kg) of equipment - a perfect solution for storing non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
Backed by a StarTech.com Lifetime warranty and free lifetime technical support.
EIA 310 Compliant
Our 2u rack shelf is EIA 310 compliant meaning it can fit most standard 19" 2 post racks. The included mounting brackets can be adjusted to accommodate different post depths, making this center mount rack shelf a universal solution for 2 post rack storage, while the vented design helps to improve airflow in the rack. -
Constructed using SPCC commercial grade cold-rolled steel, this durable 2 post network rack shelf can hold up to 75 lb. (34 kg) of equipment - a perfect solution for storing non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible. -
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. Backed by a StarTech.com Lifetime warranty and free lifetime technical support.
- StarTech.com 2U Vented 19" 2-Post Network Rack Cabinet Shelf, 20in Deep Center Mount Cantilever Tray Rackmount Shelf for AV/Data Equipment Enclosure with Cage Nuts & Screws 75lb Capacity - 2U Fixed Rack Shelf (CABSHF2POSTV2) - rack shelf - 2U
- Product Type
- Rack shelf
- Package Content
- 4 M6 cage nuts, 4 M6 screws, 4 M6 plastic cup washers
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- Cold-rolled steel
- 48.62 cm x 50.8 cm x 8.8 cm
- 5.2 kg
- Centre mount, vented, 2 post
- Limited lifetime warranty
- Designed For
- P/N: 2POSTRACK42
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Package Content
- Rack Size
- 19"
- 2U
- 48.62 cm
- 50.8 cm
- 8.8 cm
- 5.2 kg
- Shipping Dimensions (WxDxH) / Weight
- 54 cm x 55 cm x 11 cm / 5.4 kg
- Black
- Weight Limit
- 34 kg
- EIA-310-E, RoHS, REACH, ECA-310-E
- Limited warranty: - lifetime
- Designed For
- P/N: 2POSTRACK42
StarTech.com 25ft. Hook-and-Loop Cable Tie | In Stock | £4.36 |
StarTech.com 25ft. Hook and Loop Roll - Green - Reusable | In Stock | £4.37 |
StarTech.com 25ft. Hook and Loop Roll - Red - Reusable | In Stock | £4.27 |
StarTech.com 25ft. Hook and Loop Roll - Yellow - Reusable | In Stock | £4.27 |
